My Ge Top load washer will not power up start button?,no lights.
I have checked the lid switch.There is no lights on the panel.I push the start button nothing happens.
  • Washing Mach... Master
  • 8,220 Answers
Their is a fuse in the harness red wire that runs down from the control to the motor on the hydrowave washer. Hydrowave washer manual
Of course if yours isn't a hydrowave maybe you oughta post a model number. GE has several different styles.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 27, 2013
6ya staff
SOURCE:
tzweeb
Tom Zwiebel
  • 318 Answers
SOURCE: push start button on control panel - machine does not start
only 2 things can cause this.
1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
Posted on Jan 06, 2009
aborcass
Ron Coons
  • 2651 Answers
SOURCE: The lid will not lock.
you cant bypass this switch by pushing w/ screwdriver. its a magnetic reed switch open the top deck (3 screws behind the console) inside should be a tech ref sheet quite helpful trouble shoooter in ther
Posted on Feb 22, 2008
Anonymous
SOURCE: Front Loading Duet Washer will not start
I've got same problem, with the door stuck shut, door lock NOT on, water trapped in the machine, and still no solution. 8 pages of messages and no solution.
Posted on Mar 14, 2008
Anonymous
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: how to remove the front panel of a ge top load
Use a putty knife to push in the clips on the top right and left front side of the panel. These clips are about 2 inches in from each side where the top meets the front panel. When you push in on the clips position your fingers on the side of the panel to pull out as you push the clips in. Open the control console and retrieve the tech sheet inside. It will describe how to open the panel.
Posted on Sep 19, 2009
Samsung WF42H5400 AW/A2 Washer was briefly unplugged, then plugged back in. Now, it will not power on. Any ideas as to why?
hi Peggy.
Main reasons a washer will not start (either front or top load):
1. Power breaker off, washer not plugged in.
2. Lid switch faulty, door switch faulty.
3. Start switch and or timer faulty.
4. Washer motor faulty.
5. Main control board faulty or shorted.
Power to Washer
Be sure the washer is plugged into the electrical outlet in the wall. Also be sure the breaker switch in the breaker box is turned on. If you live in an older home your box may be called a fuse box. If so, make sure the fuse is in good working condition.
Door Switch Strike (Front Load Washer)
The door switch is a safety feature on front loading washing machines. On front loaders, the door switch must be closed and the door must be locked. If this switch malfunctions, the washer won't start. This switch is in the door frame of the washing machine where the door shuts. If you suspect the door switch is causing your washer to not start, carefully check the strike where it engages into the door lock assembly. Be sure the lock is working properly by keeping the door shut and locked shut. You can check the door switch for continuity with a multimeter. Be sure to disconnect the power to the washer when you check for continuity. If there is no continuity, replace the door switch.
Lid Switch (Top Load Washer)
A lid switch is a safety device located under the lid on top load washers. This lid switch will not let the motor operate when the the lid is open. If the lid switch is faulty, then the washing machine will not start. It may fill with water but will not spin if the switch is faulty. Some lid switches on top loaders also control the water inlet valve. In some top load washers, if the lid switch is bad, the washer will not fill with water. The lid switch is under the lid. There is a pin or pusher attached to the lid. This pin or pusher (when lid is closed) will press the lid switch. If your washer will not start, be sure the switch is being pressed. If the lid switch is being pressed but no power is being supplied to the washers motor, then the switch is most likely bad. To test the switch, turn off power to washer and remove the wires from the lid switch. Check the switch for continuity with a multimeter. If there is no continuity, replace the lid switch.
Start Switch and Timer (Top Load Washer)
The start switch timer on top load washers is part of the timer. This starting switch is turned on by pulling out the timer knob. If after pulling the timer knob the washer will not start, you can test it for continuity with a multimeter. Remove power from the washing machine and find the timer contacts. Some top loaders have a start switch that is a momentary contact type of switch. This switch will be located on the control panel. You can also test this switch for continuity with a multimeter while pushing the button in. Remove power from the washer before testing for continuity. If there is no continuity, replace the start switch and or timer.
Timer Knobs
Sometimes the timer knob wears out and cannot properly engage the timer shaft. If this is the case, then the knob is at fault. The knob cannot grip the shaft therefore is unable to turn the machine on. A worn knob will cause it to slip. Turn off power to the washer and inspect the back of the timer. Make sure the timer shaft engages the knob when it is pulled in or pushed out. If the knob is worn, replace it with a new one.
Drive Motor
Both top and front load washers use a motor that spins and agitates. (A top load washer uses a reversing motor) The motor spins in one direction to agitate and the other direction to spin. When the wash motor will not turn on it may be faulty. If the motor makes strange humming sounds then the motor may be at fault. To test the motor, remove the belts and try to start the motor. If it runs then you know something else in the washer is causing the issue. On newer direct drive washers, you will have to disconnect the pump and the coupling to the trans. If the direct drive motor turns on, then then you have a transmission issue or possibly the pump. If the direct drive motor won't start then it should be replaced. On front load washers the motor drives the washing basket with a ribbed belt. Remove the belt and try to start the motor. If the motor runs, then be sure the basket turns and doesn't have anything stuck or jammed between it and the outer tub basket.
Main Electric Control Board
The control board controls every component in your washer. If the main control board does not properly control the motor, the filling valve, the drain motor, or the door lock, the washer will not start. The only way to determine if the control board is at fault is to visually inspect it. Check for burned areas or any component on the board that may look burned or damaged. If you find burned areas or components on the control board, remove and replace it.
or read up more at this link.
samsung washing machine will not turn on Google Search
Dec 12, 2017 | Samsung Washing Machines
Whirlpool he washer-lid lock light flashing and lid locked. reset by using start/pause/ lock button. start washer-light comes on/sensing begins light starts flashing again and washer stops operating
LID LOCK LIGHT STAYS ON NO START:
Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
MACHINES SAIDS SENSING
When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
God is good and that's why I give free advice.
Dec 26, 2016 | Whirlpool Washing Machines
Ge washer gcrh410
May 19, 2014 | Frigidaire Washing Machines
GE top loading washer turns off by itself
How about a lid switch. Try pushing down on lid to restart.
May 10, 2010 | GE WBSR3140DW Top Load Washer
THE START BTTON ON WASHER PUSHES IN BUT DOES NOT TURN WASHER ON
HI, check the lid switch for its operational value. if the lid switch is showing good Resistance, replace the start button.
Jul 22, 2009 | GE WBSE3120B Top Load Washer
How does the top come off ge washer model wjxr2080t6ww
Use a putty knife to push the spring clips in where the top of the front panel meets the washer top, about 2 or 3 inches in from each side. Front panel pulls forward and lifts off pegs, revealing two 1/4 inch drive hex screws holding top to side panels. If your washer has the lid switch near the front, push the tab on the back side toward the center of the switch and push switch up, then twist 90 degrees and pass switch back through the opening. Now lift washer top at the front side. Most washer tops will unhook from the back side now, but some need to be slid an inch to the side yet to remove once the top is lifted a few inches. If you model still has the lid switch near the back of the washer opening, lift the top at the front and unhook the back of the washer top, pull the top forward a few inches and unplug the lid switch disconnect block. (two wires)
Oct 12, 2008 | GE WVSR1060A Top Load Washer
GE WSJR4160DOWN
You don't have to remove the washer top. Use a putty knife to push the tabs in on the left and right side, about two inches from the sides, at the top seam of the front panel. Front panel pulls forward and lifts off bottom pegs. Lid switch has a tab you need to push toward the center of the switch (its on the back side of the switch) which will allow the switch to push up. twist the switch and pass it back down through the washer top.
Oct 11, 2008 | GE WBSR3140DW Top Load Washer
GE Profile WPRE6100G will not spin
hi thanks for the question. i think the problem is with the lid switch . lifting the lid 10 times wont help if the switch is faulty check the lid switch thanks the appliance doc
Sep 20, 2008 | GE Profile WPRE6100G Top Load Washer
Don't start
It doesn't work at all If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Aug 10, 2008 | Kenmore Oasis HE 27082 Top Load Washer
GE Top Loader Washer, spin cycle not working.
When you close the cover, there is a pin push the switch down, check that one, see if it is help.
Jun 02, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
268 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
