KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
A
Anonymous Posted on Mar 09, 2013
How do I clean coils on kscs25fkss00 - KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kscs25fkss00 ice maker leaking when making ice, water seems to flow over the top
Did you check to see if the ice maker has been changed prior to this problem and if so was it a correct replacement for this refer by model #? Has the module been changed? Again, correct part ? Is the water adjustment screw on the module incorrectly set ? The last question to your problem is, has hard water conditions caused the mold to become rough due to the coating separating from the metal ? This causes the water to not flow correctly into the total mold . Hope this helps a little.
tip
Condenser Coil Cleaning Condenser Coil Cleaner
One of the most important things to maintaining a highly efficient Air Conditioner is keeping the condenser coil clean. To make your condenser coil cleaning as easy as possible you need to know what to use to clean your coil.
There are a number of different things that can be used to clean your condenser coil. It does not matter whether you are cleaning a central air conditioning unit or a window air conditioning unit. What does matter is the type and location of the coil and the amount of dirt that is in the coil.
When looking at the type of coil cleaner to be used, make sure that the chemical being used is compatible with the type of metal that the coil is made out of. Some chemicals and certain metals do not get along well and should be avoided.
Also, if you condenser coil is severely plugged then a foaming type coil cleaner is a must have item. If the condenser coil just needs to be washed down and is not completely plugged then a mild detergent may be just the tool needed to do the job.
For many units that have regular cleanings, a good quality detergent similar to what you use to wash your car, will work just fine. The main object of the cleaning is to remove the dust, dirt, and grime from the coil to promote better air flow through the coil. If the coil is just plugged with grass or dandelion seeds them a simple hosing off with the water hose may do the trick.
If a foaming cleaner is need to clean a neglected or very dirty coil then look up your local heating and air conditioning supply house and purchase a coil cleaner specifically for cleaning condenser coils. Most of these products are for professional use only and care is needed when using and handling these products.
Condenser coil cleaning can be done by the homeowner if proper care is taken and it will keep you air conditioning unit running great whether it is a central air conditioning unit or a window air conditioning unit. Once you know what to do and how to do it you may find that you will be cleaning your condenser coil a number of times a year to insure top performance from your unit.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
on Jan 10, 2010 • Heating & Cooling
tip
Air Conditioning - Cleaning the Condenser Coil
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Air Conditioning works by exchanging heat from inside a building to the outside air. To do this some very basic refrigeration principles need to take place. One of the most critical pieces that make this happen is the condenser coil. This is usually the aluminum coil the surrounds the air conditioning compressor.
What happens inside this outdoor unit is a very basic state change of the refrigerant inside the air conditioning unit. The refrigerant that changes from a liquid to a gas inside the indoor coil moves to the outside where the compressor compresses the gas under high pressure. When this happens the gas also becomes very hot. The hot gas then leaves the compressor to start traveling through the many feet of tubing in the condenser coil. As the gas cools it changes back to a liquid form going back indoors to start the cycle all over again.
Big problems start when the condenser coil becomes so blocked up with dirt that the hot gas in the condenser coil does not cool enough to change the hot gas back to a liquid form. If this happens the cooling process does not happen and then air conditioner runs but is not cooling. The compressor starts to get very hot and the ultimate result will be the death of a compressor. For these reasons the condenser coil must be kept clean and free of debris at all times when the air conditioner is running. Cleaning the coil is a fairly simple process, Here are a few guidelines to follow when doing this.
To clean the coil a few simple tools are needed. A garden hose with a nozzle, wrenches to remove the condenser fan, a garden sprayer for applying the cleaning solution. The first thing is to disconnect the power to the outdoor unit. There should be a disconnect switch of some type near the condenser. Then remove the fan from the condenser unit. Usually this will be the top of the unit. The fan can usually be laid aside carefully without disconnecting the wires to the motor. Carefully wet down the coil with the garden hose. If you have very high pressure water where you live be careful that the water pressure does not bend over the fins on the coil. These are very thin and fragile. If they get bent over the air will not be able to freely flow through them. Using the cleaning solution from the garden sprayer, coat he inside and the outside of the coil. Let the solution work on the dirt build up before washing it off. If you use a foaming type coil cleaner then let the foam cook the dirt out of the coil. Then use the garden hose to wash the dirt out of the coil. I often work from the inside spraying out through the coil. This is the reverse of the usual air flow and it washes the dirt out easier. Rinse the coil with water till it is clean with no more dirt or cleaner coming out. Replace the fan and start the unit back up.
The cleaning solution for the condenser coil can be any good household cleaner. Many automotive type radiator cleaners will work well. For very dirty condensers it would be good to buy a foaming coil cleaner made specifically for cleaning condenser coils. A local plumbing and heating supply house should stock coil cleaning solutions. Most of these solutions are very strong chemicals. Be sure to wear gloves and eye protection when working with them.
By keeping your air conditioning condenser coil clean, you will help to have your air conditioner running at the best efficiency possible. A clean condenser coil is one of the easiest ways to save electric while running your central air conditioning system. A clean coil will allow your compressor to run cooler and help it to last longer. Your condenser coil should be thoroughly cleaned at least once a year. If in you live in very dirty areas like along a dirt road you may need to clean the condenser coil more often. Also do not do things that would clog up the coil. Blowing grass clippings into the condenser coil is one common thing that happens. Keep shrubbery from growing into and around the condenser coil. This stops the air flow to the coil. Large flowers planted too close to the coil can do the same thing.
As you can see there are many things that can cause your air conditioner to work harder and cost you more money. By taking a the time to look over things and give it a cleaning you can save a lot of money.
on Dec 03, 2009 • Heating & Cooling
How many cubic feet?
The cubic feet of a KSCS25FKSS is 25 cu. ft. Thanks Sea Breeze Click Here=> Dimension Guides KSCS25FKSS00.pdf
User Manual=> KSCS25FKSS00.pdf
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download
KitchenAid Superba Model KSCS25FKSS00. My freezer is cold, coils freezing, fan blowing, but refrigerator is warm. In the last few weeks we alternated between freezing lettuce in the crisper to spoiling...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Disconnecting water line for water dispenser, do the connecters just pull apart or do you have to twist them off?
May need your model number to confirm. But older styles have the compression nut with farrow on the water line to prevent leakage.and newer types have snap lock fittings. If yours is one of the models listed above the question would be what part of the dispenser system are you attempting to remove and replace? If you model is the=> KSCS25FKSS00 then click on photo again to enlarge. All fittlings appear to have the compression nut. The water Control Valve=> 2199838 Water Inlet Valve
Here is a link to the KSCS25FKSS Parts Manual
You may also get Whirlpool User Manuals and part manuals HERE
I may not have answered exactly the answer you want but I belive you twist them with a wrench at this time.Hope this helps, Thanks Sea Breeze
4helpful
I have a KitchenAid KSCS25FKSS00 side-by-side refrigerator. Freezer suddenly began warming and noticed divider between freezer and fridge very hot. Removed back panel and noticed condensor fan was not...
Yes, you need to replace that fan...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
1helpful
Do I need to clean coils in haier hwro6xc7 air conditioner
You always need to keep both coils clean on your AC.
The evaporator coil (where room air is drawn in and through a filter) - is easy to keep clean - 'just keep the filter changed on a regular basis and you will probably never need to actually clean the evaporator coil. Occasionaly you might need to brush the coil with a brush or something - but this is not a big concern.
The condenser coil (where hot air blows from) is even 'easier,' for you don't have to mess with a filter, just keep the coil clean. You can occasionally pull the unit (when needed) and wash this coil with a water hose. In reality this coil will not get very dirty very fast - although it will (over time) acquire some dirt/dust, but as I say - it is pretty easy to keep clean. Note: Condensing units (split systems) that sit in a yard will get much dirtier much faster than window/thru the wall units such as yours, but you still have to keep a eye on the coil.
A good rule of thumb - is to change the filter (in front of the evaporator coil) - monthly.
As for the condenser coil (where hot air blows from) you can easy see it and just need to keep it clean, with no set (usually) time to do so.
good luck!
2helpful
Kscs25fkss00 superba - water not flowing to icemaker but water dispenser works - there is not ice blocking line/tray
Most times that is caused by the dual water control valve on rear of the refrigerator. You can test the ice maker by filling with water and letting it freeze. If the ice drops then the valve is the problem. If the ice does not drop then the ice maker is were the problem is, Thanks, Sea Breeze
Kitchenaid refrigerator in door water/ice dispensor
Look here.
http://www.fixya.com/support/t219770-kitchenaid_superba_kscs25fkss00
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
