Is the processor shot?
SOURCE: samsung s730 nothing comes up when turned on
when you press the power button does it show a green light?
try using batteries with 2500mAh/ 1.5 volts or higher
SOURCE: My 2GB film pro card is locked and I don't know
Move the slide switch on the side of the card.
SOURCE: my samsung es55 is overexposing
Two things to try....turn down the ISO setting....set the "exposure compensation" to a lower number.
SOURCE: hello from Bulgaria :) can
That depends on the subject matter and, more importantly, on what YOU want the picture to say. Usually for landscapes you'd want a deep depth of field while for portraits you'd want a narrow depth of field. You wouldn't want a picture taken outdoors on a sunny day to have the same mood as a picture taken at night. That's why there are so many settings. If there was such a thing as optimal settings for all pictures, we might not need anything other than on/off switch and the shutter release button.
Again, YOU must decide the settings (even if it's only to hand control over to the camera in one of the automatic modes). You and I could be taking pictures of the same thing at the same time using the same type camera, and there's a good chance we'd be using different settings. It's not that one set of settings is better or worse than the other.
the best way to avoid these lighting problems is to adjust
your aperture settings, your shutter speed and your film speed when shooting.
for more information visit this site
http://www.photoshopsupport.com/tutorials/jennifer/fix-overexposed.html
Good luck
