I have a cable from a antenna to the tv source and a xbox 360 to hdmi port and my laptop to RGB. sometimes i connect my xbox360 with component hd av cables. and it stil says NOT EFFECT.thank you Tech malick...
AnonymousMar 15, 2014
when pwr pressed no picture whatsoever but sound is clearwhen pwr pressed no picture whatsoever but sound is clear
You can't post conmments that contain an email address.
Lets start at connections. What is your cable source? Do you have a converter or cable box connected to your TV?
YES : You must have two connections, so you will need to run a second coax cable from the wall. This can be a $10 fix and a 15 min hook up. (Ask if needed). You will also have to be using your TV through caox inputs (TV Source on TV)
NO: You will need a second line ran and hooked up to your TV input. (Ask If need specific hookup on model)
Close the door or power down the tv in the other room to make adjustments to the main tv, I don't think there is a way to change the sensitivity of either screen you must shield your remote and its reflections from the other set I guess. have fun with that :)
Sansui is built by Japan firm Orion try 135 or 136 four digit try 0135 or 0310
On the remote control, press and hold the RM SET UP
button.
While holding down the RM SET UP button, press and release
the A/V I/O button.
Release the RM SET UP button.
Press the input (component) button to be controlled.
NOTE: To program a television press the TV I/O
button.
Press the number buttons to enter the numeric code corresponding
to the component and the make of the component to be controlled.
NOTE: If more than one code number is listed for the manufacturer,
enter one code at a time until you find one that works.
hi,
First of all check the remotes. You can easily check the remote is it working or not. Justpoint the remote to a digital cameras or a mobile camera and press any button . If the remote is functioning then you can see a white light blinking.
If the remote is working , then the IR receiver of your TV have some problem. you can find the IR receiver it the frond pannel pcb of your tv. i have added a picture of ir receiver. will help you to find out the same. if you need any more assistance feel free to contact me throughfixya.
ok
Do a hard restart by unplugging the tv waiting an hour and checking. If it is still stuck you have a internal component that failed on the video board.
Go into the menu. Go to CHANNEL and press enter. Go to AUTO CH MEMORY and press enter. Press the right arrow on remote to change the signal type to AIR. Go down to AUTOMATIC SEARCH and press enter. Wait for it to finish on its own. You should have all the analog and digital channels you can get with the antenna setup you have connected to the tv.
