Samsung tv
SOURCE: still need codes
codes are -->here<-- select your remote and device you wish to control
clarkco
SOURCE: ONE FOR ALL "Big Easy" urc-4330b03
There are three codes for Orion TVs: 0236, 0463, and 0179.
SOURCE: Hi, I need the codes for connecting the One For
Daewoo TV codes for a URC-4330 are:
0451, 1661, 0092, 0672, 0623
If these don't work for your model, you'll need to run through the auto code search function.
1. On the remote control, press TV once.
2. Press and hold SET until the LED
blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing POWER and TV. Stop when
the TV turns off.
5. To lock in the code, press and hold
SET until the LED blinks twice, then
release SET.
SOURCE: Need 4 digit code for One for all remote
Try
0154 0156 0060 1256
You can get a manual from
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/one_for_all/urc4330-manual.zip&area=other
SOURCE: I have a urc-4330B03 Big Easy remote and need the
I can not find a code for my tv in one for all my tv is apex
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy. Surf the site patiently.
