Cobra 148 GTL 120-Channels Base CB Radio Logo
Posted on Feb 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cobra 148 mark 2
I have a cobra 148 mark 2 fully expanded but im unable to receive or to hear anything the swar is down and people can hear me but im just not receiving anything
  • Anonymous May 11, 2010
    hbowman1
    my name is james i will try to help you i need to know if the meter is moving when you turn your radio on a busy channel like ch 19 ????
James Walker
Level 2:
Habit-Forming:
New Friend:
  • Expert 65 Answers
  • Posted on Mar 05, 2015
James Walker
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
65
Questions
0
Helped
27534
Points
126
Broken wire in the mic plug. 148 has a quiet receive also.
Mike Charette
Level 3:
Genius:
  • Cobra Master 1,847 Answers
  • Posted on Mar 01, 2015
Mike Charette
Cobra Master
Level 3:
Genius:
Answers
1847
Questions
Helped
490610
Points
2212
5 Related Answers
A
Anonymous
  • Posted on Jan 08, 2008
SOURCE: cobra 148 gtl
First take a jumper wire and connect it to the DC Ground of the input of the radio then touch it to the TX pin on the radio if it does keyes up then its in the mic or mic cord on the end of the mic plug or where it goes into the mic cable goes up inside the mic. If the radio don't key up at all then check the main voltage regulator chip one pin will have 8 volts transmit and another pin will have 8volts recieve. If you get no switching DC voltage on the regulator then its bad and needs replacing there is also a known bad capacitor in the radio thats only 10 volts change it to 25 volts at the same capacitance.
Mechanic688
Mechanic688
  • 204 Answers
  • Posted on Oct 31, 2008
SOURCE: Cobra 25 no receive & no modulation
Hello 49er, When you say "no receive", do you mean no sound, or no signal on the meter at all??I'm just grabbing at straws here so bear with me as there can be different problems doing the same thing.If this radio has been tightened up in a bracket, sometimes that will pull the solder legs loose on the audio chip. That could take away the mod. and RX volume. Is the Microphone ok? If the radio has been in storage, the switches and knobs could have dust and dirt in them. How much troubleshooting are you comfortable with?? If your not, then you might need to take it to a good CB Radio Repair shop to have it serviced. That's what I used to do for over 10 years,,, Let me know how your coming along,,, Mechanic
Anonymous
  • 9 Answers
  • Posted on Dec 06, 2008
SOURCE: cobra 148 gtl channel mods
contact me i can mod your radio for 65.00
Anonymous
  • 22 Answers
  • Posted on Apr 23, 2009
SOURCE: cobra 148 gtl dx manual
This is the Manual for the C148GTL
Sheldon Dedek
  • 912 Answers
  • Posted on Sep 15, 2009
SOURCE: Installing an Astatic Echo Board in a Cobra 148
There should have been instructions that came with your reverb board. You are going to need to drill another hole in the case of the radio, or find a control where you can install a dual control knob onto.
Your reverb board is likely going to need 8v, so you will need to locate that off the logic board, likely from the frequency synthesizer. The the audio lines from the mic, or the output of mic amp, are going to be redirected to the reverb, and the output of the reverb feed back to where the wires were removed from.
If I recall correctly, the 148 is a bit of a bear to work with, not much room inside. You will likely have to get creative in placement of the reverb board itself. Make sure to wrap well so that it doesn't get tossed around and break something inside.
I have a Cobra 148 GTL side mike jack.
There appears to be help here and that forum is the best place to ask. It is a Post Factory modification according to this.
WTB cobra 148 gtl side mic
WorldwideDX Radio Forum https://www.worldwidedx.com > threads > wtb-cobra-...
Feb 27, 2019 - 148 GTL side-mic uses 5 pin mic receptacle. If the radio in question is a side mic and has a 4-pin receptacle, then it was put in post-factory ...
Cobra 148 GTL Malaysia.. side mic?? Should I buy?
Aug 13, 2018
148gtl blown d44 and mic Jack conversion - WorldwideDX
Mar 1, 2018
Old school Cobra 148GTL.... ' WorldwideDX Radio Forum
May 13, 2019
Cobra 148gtl Basket case! ' WorldwideDX Radio Forum
May 7, 2018
More results from www.worldwidedx.com
https://www.google.com/search?q=Cobra+148+GTL+side+mike+jack
Want to lower my dead key on my cobra 148 gtl mobile...where do i find the adjuster?
need to get a watt meter hooked up to then go the where the final is and look aroung for a tuning slug marked L38 and that is the baby you have to turn in order to power down this radio.
Cobra 148 gtl-st wont transmit but receives great
Check first your microphone
• check if TX is engaging when PTT is pushed.
• check for continuity ( mic and cable )
If you have not done these steps,
try it first, or borrow other compatible mic for Cobra 148GTL
from your friends on air.
3answers
148 gtl receive issues
The problem is in the audio output chip usually bolted to the inner chassis. Sometimes the chip developes a hairline crack, replacement recommended.
4helpful
Schematic diagram of cobra 148 gtl cb radio china made
  • Locate the MB8719 chip that is right behind the channel selector. Wire a SPST switch from pin 10 to ground and another from pin 11 to pin 12.
  • Channel Chart
  • Position 1: sw1 down, sw2 down
  • NORMAL CHANNELS
  • Position 2: sw1 up, sw2 down
  • 15=26.815 20=26.885 25=26.925 30=26.985(ch3)
  • 16=26.835 21=26.895 26=26.945 31=26.995(ch3A)
  • 17=26.845 22=26.905 27=26.955 32=27.005(ch4)
  • 18=26.855 23=26.935 28=26.965(ch1)
  • 19=26.865 24=26.915 29=26.975(ch2)
  • Position 3: sw1 up, sw2 up
  • 1=27.605 6=27.505 10=27.555 14=27.605
  • 2=27.455 7=27.515 11=27.565 16=27.475
  • 3=27.465 8=27.535 12=27.585 20=27.525
  • 4=27.485 9=27.545 13=27.595 23=27.575
  • 5=27.495
  • Position 4: sw1 down, sw2 up
  • 1=27.605 11=27.725 21=27.855 31=27.955
  • 2=27.615 12=27.745 22=27.865 32=27.965
  • 3=27.625 13=27.755 23=27.895 33=27.975
  • 4=27.645 14=27.765 24=27.875 34=27.985
Have a new cobra 148 gtl took out of box no transmit or recieve
make sure that your [swr] hadn't changed or went higher than a 1.5, anything higher will interfere with your tranmitting an recieving. other than that with out being there to see an hear your radio this would be the first place to start.
2answers
Want to disconnect the bleep altogether on my cobra 148 gtldx
If this is a stock cobra 148 gtl 40 channel am plus side band, they don't to my knowledge come with a built in r beep. Some roger beeps are instaleed through the transmit circuit on the mic, so if not in the know Don't try to fix it.Some microphones have a beep built in. I used to install beeps on these radios using the pa/cb switch to turn them on. also try the nb switch or the swr/rf switch.
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
