I try to install visual studio 2005 in my vista laptop but, show some error during instalation,,,
this is my error afterinstalation
[01/08/09,08:15:43] Microsoft Visual Studio 2005 Tools for the Microsoft Office System - ENU: [2] ERROR:Error 1935.An error occurred during the installation of assembly 'Microsoft.VC80.DebugCRT,type=''win32'',version=''8.0.50727.42'',publicKeyToken=''1fc8b3b9a1e18e3b'',processorArchitecture=''x86'''. Please refer to Help and Support for more information. HRESULT: 0x80070422.
[01/08/09,08:15:43] Microsoft Visual Studio 2005 Tools for the Microsoft Office System - ENU: [2] ACTION FAILURE:Action ended 08:15:43: InstallFinalize. Return value 3.See MSI log for details.
[01/08/09,08:17:10] Microsoft Visual Studio 2005 Tools for the Microsoft Office System - ENU: [2] ACTION FAILURE:Action ended 08:17:10: INSTALL. Return value 3.See MSI log for details.
[01/08/09,08:17:44] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InstallManagerHelper() with HRESULT -2147023293.
[01/08/09,08:17:44] setup.exe: [2] Component error string not specified in ISetupManager::AddToActionResultCollection()
[01/08/09,08:17:45] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2005 Tools for the Microsoft Office System - ENU is not installed.
[01/08/09,08:17:45] VS70pgui: [2] Unknown component status forMicrosoft SQL Server 2005 Express Edition x86
llllllllllllllllllllllllllllllll
[01/08/09,08:18:42] VS Scenario: [2] *** Blocking Components exist and must be satisified before continuing to install ***
[01/08/09,08:18:42] VS Scenario: [2] Windows XP Service Pack 2 Update Information
[01/08/09,08:18:42] VS Scenario: [2] *** End of Blocking Component List ***
[01/08/09,08:18:54] VS Scenario: [2] Failed to pass the Warnings/Blocks checks in CVSScenario::Start()
[01/08/09,08:28:49] Microsoft Visual Studio 2005 Tools for the Microsoft Office System - ENU: [2] ERROR:Error 1935.An error occurred during the installation of assembly 'Microsoft.VC80.DebugCRT,type=''win32'',version=''8.0.50727.42'',publicKeyToken=''1fc8b3b9a1e18e3b'',processorArchitecture=''x86'''. Please refer to Help and Support for more information. HRESULT: 0x80070422.
[01/08/09,08:28:49] Microsoft Visual Studio 2005 Tools for the Microsoft Office System - ENU: [2] ACTION FAILURE:Action ended 08:28:49: InstallFinalize. Return value 3.See MSI log for details.
[01/08/09,08:30:23] Microsoft Visual Studio 2005 Tools for the Microsoft Office System - ENU: [2] ACTION FAILURE:Action ended 08:30:22: INSTALL. Return value 3.See MSI log for details.
[01/08/09,08:30:59] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InstallManagerHelper() with HRESULT -2147023293.
[01/08/09,08:30:59] setup.exe: [2] Component error string not specified in ISetupManager::AddToActionResultCollection()
[01/08/09,08:31:00] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2005 Tools for the Microsoft Office System - ENU is not installed.
[01/08/09,08:31:00] VS70pgui: [2] Unknown component status forMicrosoft SQL Server 2005 Express Edition x86
pls help me
Troubleshoot Visual Studio installation and upgrade issues
The following steps apply to a typical online installation. For an offline installation, see How to troubleshoot an offline installation.
Step 1 - Check whether the problem is a known issue
There are some known issues with the Visual Studio Installer that Microsoft is working on fixing. Check if your problem is already solved, or find workarounds, in the Known Issues section of our release notes.
Step 2 - Try repairing Visual Studio
Repair fixes many common update issues. For more about when and how to repair Visual Studio, see Repair Visual Studio.
Step 3 - Check with the developer community
Search for your error message in the Visual Studio Developer Community. Other members of the community might have found a solution or workaround to your problem.
Step 4 - Delete the Visual Studio Installer folder to fix upgrade problems
The Visual Studio bootstrapper is a light-weight executable that initiates the install of the Visual Studio Installer and then the Visual Studio product. Deleting the Visual Studio Installer files and then rerunning the bootstrapper solves some update failures.
Note
Performing the following actions reinstalls the Visual Studio Installer files and resets the installation metadata.
Close the Visual Studio Installer.
Delete the Visual Studio Installer folder. Typically, the folder path is C:\Program Files (x86)\Microsoft Visual Studio\Installer.
Run the Visual Studio Installer bootstrapper. You might find the bootstrapper in your Downloads folder with a file name that matches a vs_[Visual Studio edition]__*.exe pattern. Or, you can download the bootstrapper for your edition of Visual Studio from the Visual Studio downloads page. Then, run the executable to reset your installation metadata.
Try to install or update Visual Studio again. If the Visual Studio Installer continues to fail, proceed to the Report a problem step.
Step 5 - Report a problem
In some situations, such as when there are corrupted files, issues might require case-by-case troubleshooting. To help us help you, follow these steps:
Collect your setup logs. See How to get the Visual Studio installation logs for details.
Open the Visual Studio Installer, and then choose Report a problem to open the Visual Studio Feedback tool. Screenshot showing the Provide feedback button in the Visual Studio Installer.
Give your problem report a title, and provide the relevant details. The most recent setup log for the Visual Studio Installer is automatically added to the Additional attachments section of your problem report.
Choose Submit.
Step 6 - Remove Visual Studio installation files
As a last resort, you can remove all Visual Studio installation files and product information:
Follow the steps in this article: Remove Visual Studio page.
Rerun the Visual Studio Installer bootstrapper. You might find the bootstrapper in your Downloads folder with a file name that matches a vs_[Visual Studio edition]__*.exe pattern. Or, you can download the bootstrapper for your edition of Visual Studio from the Visual Studio downloads page.
Try to reinstall Visual Studio.
Step 7 - Contact us (optional)
If none of the previous steps help you successfully install or upgrade Visual Studio, contact us by using our live chat support option (English only) for further assistance.
Offline installations
Here are some known issues and workarounds that might help you when you create an offline installation and install from a local layout.
Users can't access filesMake sure that you adjust the permissions (ACLs) so that they grant read access to other users before you share the offline install.
New workloads, components, or language packs fail to installMake sure that you have internet access if you install from a partial layout and if you select workloads, components, or languages that weren't previously downloaded for that partial layout.
To resolve issues with a network installation, see Troubleshoot network-related errors when you install or use Visual Studio.
Administrator Updates
Administrator updates may not be applied correctly due to a vareity of situations. Refer to the Administrator updates troubleshooting error codes for further information.
Installation logs
Setup logs help us troubleshoot most installation issues. When you submit an issue by using Report a Problem in the Visual Studio Installer, the most recent setup log for the Visual Studio Installer is automatically added to your report.
If you contact Microsoft Support, you might be asked to collect setup logs by using the Microsoft Visual Studio and .NET Framework log collection tool. The log collection tool collects setup logs from all components installed by Visual Studio, including .NET Framework, Windows SDK, and SQL Server. It also collects computer information, a Windows Installer inventory, and Windows event log information for the Visual Studio Installer, Windows Installer, and System Restore.
To collect the logs:
Download the tool.
Open an administrative command prompt.
Run Collect.exe in the folder where you saved the tool.
The tool generates a vslogs.zip file in your %TEMP% folder, typically at C:\Users\YourName\AppData\Local\Temp\vslogs.zip.
Greeting,
Rachel Gomez
Just take a look to this site:
http://www.codeproject.com/
you will get your answer there easily.enjoy it!
