Most re-chargeable batteries are 1.2V each, totalling 2.4V. The Z712IS Camera is designed for 3V operation. Therefore using 2 re-chargeable bats is not enough, UNLESS they are 3 or 3.7V.
Digital cameras in general use a lot of battery power; this one in particular is noted for short battery life. When it was new, this camera was supplied with a Lithium Ion battery for longer life; if you're using regular AAs, the battery life will be disappointing. Oh, and cheap batteries from the dollar store might not even work at all!
The most cost effective solution is probably high capacity NiMH rechargeable batteries; get a set of four so that you can have spares on hand. If even that isn't acceptable, look into getting the Lithium Ion one.
If you bought this camera used, the short battery life could easily be the reason the original owner got frustrated with it.
It is not possible to buy a viewing screen for KODAK cameras.
An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to arrange your repair/Trade up: Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Can you try to turn off the Flash? as this is the only part where it drains the power much to keep the capacitor charged. Try this and at the same time you can check if any firmware upgrade is also available online or some other source on the net.
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
