Universal Remote Control 6-Device Universal Remote Logo
Pat Moore Posted on Mar 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bought LG tv need to set up my universal rx450 remote
Just need to program my old RX450 remote to turn LG tv on and of can change channels but not sound and on/ off??
Level 3:
Top Expert:
  • Universal Re... Master 76,851 Answers
  • Posted on Mar 12, 2013
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007163
Points
237762
Setup codes to check with LG brand TVs are 0734,0722,0711,0000,0793. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on May 25, 2008
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Anonymous
  • Posted on May 24, 2009
SOURCE: i have bought a universal
http://www.universalremote.com/resources/pdfs/avex_manual.pdf
Anonymous
  • Posted on Jun 15, 2009
SOURCE: NEED CODE FOR SETTING GE UNIVERSAL REMOTE FOR SONY TV
I HAVE A GE UNIVERSAL REMOTE AND I NEED THE CODE TO PROGRAM A SONY TV
chitownbob45
chitownbob45
  • 316 Answers
  • Posted on Oct 03, 2009
SOURCE: Have a Universal Remote by LIVING SOLUTIONS, A17G0510
Try the code search with your remote.
1. Turn off your device
2. Hold the button of what you want to program (TV,VCR,DVD) until the red LED light lights up
3. Press the power button
4. Keep pressing Channel up/down until the device turns on
5. Press “OK”
6. Press power and volume/channel buttons to check it
Anonymous
  • Posted on Mar 04, 2010
SOURCE: I need to program ge universal remote jc024 for
I also lost the manual for my GE JC024 Universal Remote. I remembered though that you just hold in the button for the device you want to program and the "SETUP" button at the same time for about 5 seconds until the red light on the remote flashes and stays lit. then let go of the buttons.Then you basically just press and let go of the on/off button, pausing for a second or two in between presses until your device turns off. then you have to press the "ENTER" button and it'll store the code for that device. This method just cycles thru all of the possible codes for that device. sometimes you get the wrong code and the remote wont completely work. like hitting the volume button makes the tv mute for example. just repeat the steps until the device turns off again and eventually you should be able to get it. hope this helps.
1helpful
Zenith hotel TV turns itself on
Most of the Hotel sets use a different remote to enter the hidden menus--the system that set uses was likely on channel 81 and where it was used they needed it to come on at a specific time----going to get that specific service remote and info on how to change settings---this is the issue with buying these commercial sets.
Zenith is part of LG but different phone numbers etc
Why won't any universal remotes work with my LG tv?
The two possible reasons are:
1. None of the codes are correct for this model.
2. The remote infrared receiver in the set is bad.
(maybe the reason the other person got rid of the set?)
There are some ways around this depending on how you hook up and what you have for signal:
If a box (cable or sat) is connected to one of the sets of audio/video jacks on the set--switch to that input and change channels etc with the box!
Use the box remote for functions like channel and sound etc.
1helpful
2answers
HAVE LG DU-27FB32C LG TV. DO NOT HAVE A LG
There should be buttons on the cabinet to control the TV. Are the buttons on the cabinet not working?
Can't auto program Zenith TV for cable channels
  1. Did you try to call LG/Zenith customer support and see if they can help you? If not find your nearest LG/Zenith service center (not Best Buy) preferably a small service shop to see if they have a service remote to unlock it
Need code to enter for my remote to control a Yamaha RX450 receiver
G'day mate
What model TV, remote and amplifier do you have? I can help you with a little more info
regards
Graeme
4helpful
2answers
Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
1helpful
2answers
After programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Top Universal Remote Control Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
