Tumi Dakota Tough Compass Clip Watch Logo
A
Anonymous Posted on Mar 11, 2013
HOW TO CHANGE THE BATTERY ON A Dakota Tough Compass Clip Watch
2helpful
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 • Watches
3helpful
4answers
HOW DO I RESET THE TIME ON A DAKOTA COMPASS WATCH
http://buydakotawatches.com/PDF_FILES/Digital.pdf this link should provide you with the information needed to set your watch.
you may try this link as well if you need more or diffrent info http://www.buydakotawatches.com/Instructions.aspx
I hope this was helpful.
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • 6helpful
    2answers
    How do I change the battery/ies for the watch? The red light still functions, but the timepiece does not.
    I took a clip watch to the Mall today and had the battery replaced at the Dakota Kiosk. It cost $10. They used a tiny knife to pry off the back. I was trying to use a screwdriver and that didn't work.
    5helpful
    Battery in a Polar F7 heart rate monitor
    Hello
    You can change the battery in your polar f7 if the battery is worn out.
    1. Insert the tip of a pen knife into the lifting point and lifting the back up. The back of the watch is only pressed into place and will come off easily this way.
    2. Grab the small clip that is extending across the surface of the battery with a pair of tweezers. Slide the tweezers toward the end that hooks down into the watch. Pull the hook end of the clip out of the watch and remove the clip from the battery
    3. Match the old battery with a new one at any electronic store. The store will be able to read the writing imprinted on the battery to make sure that you get the correct battery type for your heart monitor.
    4. Press the new battery into the watch making sure that the writing on the battery is facing up.
    5. Press the holding clip back into place. Handle the clip with tweezers only, since it is very thin and can be bent or lost easily. Once it is in place, press the back of the watch on.
    GOODLUCK
    How do I change a watch battery in Le Clip Swiss watch? The back doesn't seem to open. The replacement battery is Renata 26.
    I contacted the manufacturer. You remove the crown, then use tiny attachment to a bike pump to push air into the interior of the watch. This will cause the crystal and dial to come apart. Viola!
    Jun 27, 2009 • Watches
    11helpful
    Need a watch manual or instructions
    A-Tech watches are sold under Dakota name. Here is the link for manual (best I could find):
    https://dakota.webfeatsecurity.com/PDF_FILES/3sensorpt2%5B1%5D.pdf
    Use zoom to get a better view.
    Rate me, please.
    Mar 20, 2009 • Watches
    1helpful
    Watch battery number for dakota watch
    This watch requires a size 1620 battery, available at all Dakota Watch Company store locations, and most electronics stores. Dakota Watch Company always recommends taking your watch to one of our store locations or a reputable jeweler to reduce the risk of damaging your watch during a battery change.
    We are sorry to read of your trouble with receiving technical support. We will be happy to answer any questions regarding your Dakota watch. Please feel free to contact our Customer Service by email at [email protected], or by phone at 1-888-459-0404. Thank you!
    Lose or gain time?
    We are sorry to read of the trouble you have experienced with your Dakota watch. The problem you have described is typically a mechanical issue that requires a movement overhaul completed by our repair department. Depending on the details of your purchase (date, place of purchase, receipt, etc) this service may be covered under warranty. To determine how to submit your watch for repair, please visit your nearest Dakota Watch Company store location, or contact our Customer Service by email at [email protected], or by phone at 1-888-459-0404. Thank you!
    Dakota digital compass-three button
    here is the site for the dakota watch company. find your specific product, click on the item for more details. on the left column their is a "instrution" tab under resources. you may need to scroll down to find it.
    i hope this helps.
    Aug 13, 2008 • Watches
    Top Tumi Watches Experts
    john h
    ADMIN Eric
    ADMIN Eric
    ADMIN Andrew
    ADMIN Andrew
    Are you a Tumi Watch Expert? Answer questions, earn points and help others
