If you printing is just faint, need to replace toner, but if your printing is faint and blurry, need to add grease to the fuser film roller, need advanced skills for that, disassemble the fuser unit take out the fuser film and put some special high temp grease on the heating element, assembly all back and install, the other way is replacing the fuser unit
SOURCE: Brother HL-2070N
did you remember to remove the seal on the toner cart? this is a breakaway tab usually on the side, this when pulled removes the plastic seal,(from inside the cartridge)
SOURCE: HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
SOURCE: Brother HL 2070N Drum Unit changed but printing with dots on the left hand side
Hi yvonnetyndal,
1\ if the dots is repeated in equally length vertically, that means the problem is from drum.
2\ if it scuttered dots that means the printer dirty by toner , try to clean it .
Hope this helpful for you,
thanks
Hamedo
SOURCE: Brother HL-2070N Will Not Print
Hi tom8972
try to reinstall the driver of it.
hope this helpful for you,
thanks,
Hamedo
SOURCE: Printing lines
Try to print calibate your printer! It is usually in your properties section of your printer options and then go to the a section that will get you a cleaning too. Failing that then try to take it all apart again and put it back together making sure it's all locked in place and do another cleaning and alighnment.
Cheers
Al
