Microsoft Surface RT Logo
A
Anonymous Posted on Mar 12, 2013
Surface rt password recovery - Microsoft Surface RT
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
MS surface will not turn on
1. Assume battery has sufficient charge
2. Assume no physical damage to unit, liquid, dropping etc
3. When turned 'on' can an updated OS be installed?
4. Any other faults or problems noticed?
5. Remove all peripherals and reboot
6. Go to this link: www.microsoft.com/surface/en-gb/support/warranty-service-and-recovery/surface-wont-turn-on
Good luck.
How do I shut down my Surface RT
if you do not mind loosing any data press and hold reset button for 30 seconds will set back to factory default settings or snap case open and try cleaning button surface where it connects
How do i get my RT to boot
Here are the steps to go back I factory setup. It will remove everything personal you have on the Surface - photos, docs, etc. They will still be in the Share drive if you utilized it for storage.
  1. Restart the device made for Surface.
  2. Press F8 during the initial BIOS post to bring up the Advanced Boot Options screen.
  3. On the Advanced boot options screen, use the arrow keys to highlight Repair your computer, and then press Enter.
  4. Select a keyboard layout, and then click Next.
  5. Type the user name and password of an administrator, and then click OK.
  6. Under System Recovery Options, select Reinstall Windows. This option will restore Surface to the factory image, and any customized user information will be lost.
  7. When the restoration of the factory image is complete, the device made for Surface will restart, and the setup process will begin. This process is identical to the first time you set up Surface; you will be guided by a series of prompts and dialog boxes.
One more note - if you deleted the restore folder to save drive space this will not work. You'll need to take to tech support.
Good luck.
How do i bypass password screen for microsoft surface rt
Microsoft Surface Microsoft Surface I have provided two links or you may call for help at 225-290-5733
Surface rt is slow and freezes
Sounds like you need to do a system refresh, RT is usually quite responsive.
Swipe right to open charms menu, then click on Update and Recovery, then Recovery, then choose "Refresh you PC without affecting your files".
Good luck.
1helpful
Youtube com
delete the old one password from settings menu then restart and give the new one your own gmail id and password.
Top Microsoft Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
