I have a Nexus 7 with wireless access. I bought a micro USB to USB adapter to use my Sprint 4G plug in when I ride the train. Is there any way to use this device or do I need something different?
(Using a WIFI Hotspot is definitely recommended. Connecting your 4G USB dongle to the Nexus 7 will drain the battery quickly since the USB is using the Nexus's battery to power on. This is what I use) but here's how to get your 4g usb dongle to work
Your device must be rooted, and you would need a USB OTG cable/adapter. Here's an example of an OTG USB cable -This app should work on any nexus 7 and it is very simple just install the app and enter your apn of your operator connect your dongles via otg cable and it will work the app available on google play store called ppp widget here is the link it is for rooted device
PPP Widget
Thanks. I actually have that exact adapter. I ended up exchanging the dongle with Verizon for a jetpack mobile hotspot (4620LE). It works great and I can use it with my phone as well. I'll keep the app in mind in case I need to use it in the future. Thanks again!
There is a post on the Google Play PPP Widget page saying it does not work on a Nexus 7 with Android 4.3, so that is a good update. Thanks
Wi-Fi technology enables wireless Internet and network access through public and private hot spots.
These hot spots are widely located in homes, restaurants, bookstores, coffee shops and other businesses, so you can keep connected wherever you may travel.
To connect to Wi-Fi, you must have an enabled wireless adapter on your computer.
Most modern laptops and many desktops have this adapter built into the system, but many lack such capabilities.
However, a wireless adapter is easily installed via USB, which allows you to connect to available networks through Windows 7.
Enable your wireless adapter. Most laptops have a hot key labeled with a radio antenna.
Hold the "Fn" key and press this key to toggle wireless on or off.
Desktops likely have a physical antenna on the back of your computer that is typically always on. If you don't see such a hot key or antenna, you need to acquire a USB wireless adapter.
Attach the USB wireless adapter to an available USB port on your computer.
Windows 7 will automatically install the necessary drivers for most adapters.
If it does not, insert the CD that came with the USB wireless adapter into your drive and choose to install their drivers.
Restart your computer if you do not see a wireless icon in your Windows 7 notification area.
Click the wireless icon in the Windows 7 notification area and click the network name to which you want to connect.
If this is your home network, the correct network will likely be the one with the strongest signal.
Click "Connect" and enter the wireless security passphrase, if required.
Only secured networks will ask for a passphrase, but some public networks will require browser authentication instead.
Open your browser and navigate to any website.
If the hot spot requires browser authentication, your website request is redirected to an information page.
Follow the instructions on this page to get Wi-Fi.
This may entail clicking "Accept," entering a given password or entering a cell phone number.
After authentication, attempt your website again to verify accessibility.
Hope this helps
