Need the factory combination for a sentry safe model number MSW 3517
SOURCE: sentury safe Model MSW3517
HI , I have the Sentry Safe Model # MSW3517. After 10 months of owning this safe the batterys went bad. I replaced the batterys with new ones and the safe still would not open.I checked online and so many people were having the same problem. I called customer service, Who told me to bang on the safe door with a rubber hammer ( What ever are they talking about ) I studied this safe design and found out that the battery holder went bad.Not making a steady contact with new batterys, Went to my local radio shack store and for ( 1.99 $ ) replaced the factory battery holder and now the safe opens with no problems..Very cheap and simple fix.You will have to cut the 9v battery connector plug off the red & black factory wires to connect the new battery holder for this to work.Very easy to do.. goodluck....
SOURCE: Forgot Digital Combination of Sentry Safe Model #SO500
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
They should be able to help. I would try calling first, to avoid paying the $12 to retrieve the combo, but with the serial number of the safe, they SHOULD be able to help you over the tele.
SOURCE: lost codes
would you know the factory recovery code for sentry 1610 as
i lost it or it is locked in my safe. My battery has been dead
for some time and I think it lost it's memory.
SOURCE: cannot open sentry safe, model 1230, have combo
cannot open sentry safe, model 1230, do not have combination
SOURCE: sentry codes v260
You should have received two skeleton keys when you bought the safe. They will open the safe without the key AND without the code. If you don't have it, the only solution is to get help from Sentry. By following the instructions below, they will send you a skeleton key for your safe.
First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe (outside). Send this, a notarized letter(last name must be different) stating you are the safe’s owner, and a check or money order or $8.00 (U.S. funds) to:
Sentry Group Dept. 200
882 Linden Ave
Rochester, NY 14625-2784
If using a credit card (Visa/MasterCard only), call 1-800-828-1438.
Hello guys! I need factory code of CSW4747 bec, my manuel is missing!
