Auria 55" 1080p 120Hz LCD HDTV Logo
A
Anonymous Posted on Mar 14, 2013
Who sells parts for 55 inch auria eq5588 tv picture not working
Volume working but picture not working
Anthony crain
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 17, 2015
Anthony crain
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
215
Points
Www.shopjimmy.com
I have a rca rcu404 universal remote that I can't get to work for a 32 inch auria tv
Auria TV 5 Digit Remote Control Codes
11423
10017
11265
10178
10856
11178
Auria TV Codes for RCA 3 in 1 Universal Remote = 12087
ON MOST REMOTES (Generalized):
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
No one buys Universal Remotes, they are so 1990s :>D You buy a facsimile remote which is an exact copy of the original, no programming needed and all the original functions.
https://www.google.com/search?q=32+inch+auria+tv+replacement+remote+control
Your search query is 'make model replacement remote control'.
How do you connect an auria eq5588 tv to a bose solo 15/10 tv sound system
Make the connection to the "Variable Audio" output jack of the TV.
My auria eq5588 has no picture but has sound if u hold a light to it u can faintly see the picture
This does not have a replaceable bulb like a DLP projector. If you cannot adjust the brightness, then there is a fault with the backlighting. This is not anything you could replace yourself.
My 55" Auria tv turns on and i have sound but no picture,what can be done to fix my issue.
What type of connection? and check and make sure the connection works with another monitor/screen
My remote suddenly stops working? Auria EQ5588-tried new batteries
I also have an Auria EQ5588 with the same problem. The remote works when the TV is cold. But after the room warms up, it no longer works. Does anyone know where the IR receiver view port is? May just need to be better aligned with the view port.
I am having trouble getting the screen size back to full size. We used the zoom but that makes the picture to big. My TV is a Auria EQ5588
Hi, The " Size " of a flat panel tv ( when not in zoom mode ) is actually controlled by your programming, if using an hdmi cable from an Hd/Blu-ray player-then whatever format the disc was recorded in is what you'll see ( widescreen/letterbox ) black bars at top & bottom of scrteen ) or full screen. Local over the air digital H.D. brodcast's from networks varie from full screen to letterbox-satellite and cable that are standard definition will almost always letterbox a screen for you. Using T.V.s tuner may alleviate most of the issues. Good luck and I hope this helped. Prodzilla
My remote doesn't turn on my tv AURIA EQ5588, do I need a code
I also have an Auria EQ5588, the on screen prompts are the same as my APEX 32" 720p I bought over a year ago so either both are the same company or they share the same software. Both are Chinese Mfg. so who knows??? If your factory remote doesn't work call the phone # on the warranty page. There are universal remote codes listed on P. 6 of the owners manual if you are trying to code a cable or dish remote. There is also a reference to LG codes which are carried by Best Buy, Perhaps they can help you out if nothing else helps. The only glitch I've noticed is switch back to TV before turning off your blue ray player. If I turn off my Sony blue ray player and then go back to TV mode I get no sound, turn off the TV and restart it and it's fixed. Seems to be an issue between the brands. I'm pretty happy with the Auria since I got it for $700. Could have spent a lot more!!!!
2helpful
Auria eq5588, cannot find code for DTV.
Auria is not even in the menu here so I had to select DirecTV DVR DTV. Someone needs to keep up with the brands. Anyway, the DTV codes for the Auria EQ5588 are: 11423, 10017,11265, 10178, 10856,11178 These are the codes. Mine worked with the first one.
Top Auria Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Auria Televison and Video Expert? Answer questions, earn points and help others
