SOURCE: How to round up to 2 decimal places?
can you tell me the answer to this question
round 618 to two decimal places
SOURCE: how do i get my
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
SOURCE: how to set the decimal
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
SOURCE: How do you get more
Press SHIFT then MODE. You can then press 6 to select Fix, followed by the desired number of digits after the decimal point, or press 8 and select one of the two Norm modes.
Full details are on pages E-5 and E-6 of the manual. If you need a manual, you can download it at
http://support.casio.com/pdf/004/fx-83_85GT_PLUS_E.pdf
SOURCE: I need to determine how
Press [SHIFT][MODE][6][4]:
When you select FIX (by pressing [SHIFT][MODE][6] ) on your calculator
you can specify number of decimal places which are displayed (you can
choose any number from 0 to 9).
