ALSO I HAD SUM TRANSMISSION WORK DONE BUT NOW HEN MY TRUCK IS IN PARK IT ISNT ENGAGED ALL THE WAY AND IT WILL ROLL.. WOULD THIS HAVE ANYTHING TO DO WITH THIS PROBLEM? I WAS THINKIN THAT IT MIGHT NOT DUE TO THE FACT THAT I HAD THIS PROBLEM HAPPEN BEFORE THE TRANSMISSION WORK WAS DONE.
SOURCE: 2005 Chevy Tahoe back door won't stay open...slams shut
no you probably have to change the lift gate struts/supports that are on the liftgate itself. very easy to do and they sell them at the autoparts store i would say for around 30-60 bucks
SOURCE: 1997 Chevy Suburban
Check the starter Solenoid. This is a common problem and can be fixed pretty cheap.
SOURCE: THE IGN A FUSE UNDER THE HOOD KEEPS POPPING
You have a serious short. The fuse is keeping you from frying the electrical system. Did you make any changes to the vehicle recently? Is it all stock electrical? If so, check the Ignition relay in the alternate fuse panel. If that does not work, post a reply and I'll help you dig further. Hope this helps
SOURCE: Is there a access panel to change a fuel pump on a
That is not something many domestic auto manufacturers offer. that is mainly a foreign concept. you will need to drop the fuel tank which is a big undertaking for someone without the proper tools and equipment. I have heard of a local shop burning down in NYC because of complications during a fuel pump change.
Testimonial: "Thanks for your quick response to my question. really appreciate it!!"
