Frigidaire FWTBB30DS Front Load Washer Logo
Posted on Feb 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code F03 my washer machine model FWTBB30DS (frigidaire gallery front load)write the F03 code after few minutes running, in any mode. thank you steve
Anonymous
Level 1:
  • Contributor 13 Answers
  • Posted on Mar 29, 2009
Anonymous
Contributor
Level 1:
Answers
13
Questions
0
Helped
17485
Points
78
I just had this same problem, it was a bobby pin stuck in the drain motor.... hope this helps
Anonymous
Level 3:
  • Frigidaire Master 3,361 Answers
  • Posted on Feb 25, 2009
Anonymous
Frigidaire Master
Level 3:
Answers
3361
Questions
Helped
1028990
Points
10654
Typically a low water or no water coming in problem. Sometimes a drain problem.
I have a Frigidaire Gallery Series front load dryer bouncing between PAU & F03 error codes. What part do I need to order so that I can replace it?
F03 is heating element circuit issue and PAU is drive motor power interruption.
I would imagine the F03 could be cause by the same power issue that effects a PAU.
The list of PAU probable cause is;
Control board
Door switch
Thermal limiter
Motor problems
I see one common denominator; the thermal limit.
1helpful
Front load frigidaire washer w/ error code F03....doesnt want to drain. Tried spin/drain, delicates, and normal and all end up with F03!! Please help!!! Thanks Royce
The F03 code is a problem with your water system. your inlet valves may have failed.
Open up the bottom panel and you will find a tech sheet that explain the codes and gives trouble shooting techniques. here is the service manual, good luck, hope this helps......
http://frigidaireservicetips.com/pdf...icControls.pdf
1helpful
Wont drain water out frigidaire gallery model fwt449fs2
at the very bottom on the front panal you will find two screws, take those out, the panal will drop out of place
rith there on your right, you will see the pump
put down a few towels
disconnect the hoses and make sure the pump and motor are clear
Dirt streaks appear after laundering
Grease seal for the bearings need to be replace. Unless you are a DIYer this is an expensive repair. Labor to install a new grease seal is about 400 to 500 dollars depending on the area. Parts will run about 100 to 150 dollars. The grease seal is cheap about a $10.00 part, but since ypou have the washer torn apart, and the grease seal has fail, you should also replace the bearings.
Front load washer
Possibly the door switch...check for adjustment or replacement
WATER LINKING AT THE BOTTOM
Had same problem, found a 4 inch hose on left rear leaking, not properely installed. This corrected the problem after making correction.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
