KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
Dan Thompson Posted on Aug 02, 2007
Kitchen Aid Ice maker Stopped working
The Ice Maker on our Kitchen Aid Superba Model KSCS251 stopped working. Water is still being dispensed, the ice maker control is turned the on position, I have unplugged the refrigerator and plugged it back in. Freezer temp has been reset to 0 and then it goes back up to 11 degrees. Nothing seems to obstructed in the ice maker. Nothing is frozen over. Thanks, Danny Bob
  • 13 more comments
  • Anonymous Nov 08, 2007
    ice maker not working
    water works OK
    inplugged and reset fridge mant times
    green light for icemaker often goes off and even though I rest it, no ice gets made
  • kuyaa Nov 23, 2007
    ice maker is not making ice
  • Anonymous Dec 04, 2007
    SUPERBA 25.2 side by side ksrg25fkss Same problem here ---water in door is fine ice machine stopped functioning. Local Lowes guy said it happens often and to take things out of top shelf (inckuyding ice maker) and blast with a hair dryer for 15 minutes as most likely the filler hose to the icemaker is frozen. Have yet to try but am ready...
  • bjorowland Dec 20, 2007
    ice maker not working - water is being dispensed from the door
  • Anonymous Jan 09, 2008
    My ice maker stopped making ice, after three years of having the ice maker work. The red light for the ice maker is on. Water works fine. A repair guy came out and replaced the whole ice maker unit, still no ice is being made. Not sure what the problem is. Hmmm.....
  • nikohelle Feb 02, 2008
    Replaced the optics boards but still no ice harvest
    Used hair dryer in case frozen water not the case
    Took out motor which seems fine
    Seems no power going into the motor
    Water/ice dispenser works ok
    What else can i replace or do??
  • Anonymous Apr 08, 2008
    Ice maker is not working, but water is coming out fine. I will try to take everything off the top shelf and blast with a hair dryer. It is an expensive refrig and I am not pleased. I would welcome any other ideas.
  • bob lad Oct 09, 2008
    i have the problem of no ice. water works, no ice.
  • Anonymous Nov 07, 2008
    Exact Problem.  Began experiencing problem when water filter was changed.
  • bjwilliams74 Dec 26, 2008
    have water no ice
  • mikeputnik Mar 28, 2009
    I to have same problem .
    I wish if you don't have something useful to say , say nothing, don't speculate.
  • tobewise May 01, 2009
    what does it means when the red light by the sensor is flashing?
  • MICHAEL BRYAN
    MICHAEL BRYAN Dec 13, 2013
    NOTHING BUT OVERRATED JUNK!
  • Anonymous Mar 16, 2014
    Is there a reset button on kitchen aide refrigerator KFIS29BBMS
  • Anonymous Mar 27, 2014
    Ice maker works. All fans work. Frosty ice forms on rear of freezer.
A
Anonymous
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
1 Related Answer
Anonymous
  • Posted on Sep 16, 2008
SOURCE: Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
I hooked up my refrigerator and the ice maker is not working.it's a kitchen aid superba kscs251
First make sure your water valve is working . If so , look for fill tube that fills ice maker to be frozen. If it is frozen , unthaw tube. If its not then replace the ice maker.
1helpful
2answers
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Ice Dispenser on Kitchen Aid Model KSCS25FTBL has stopped working
It can be faulty ice maker assembly and needs to be replaced.
Sometimes it visually sees ok,but actually its worn out or cracked causing the problem.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
These will help.
Thanks,.
Water, but "no ice" in my Kitchen Aid
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
This will help. Thanks. Helpmech.
1helpful
Ice maker in Kitchen Aid stopped making ice
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
3helpful
Kitchen Aid side by side model #kscs25inss00 The ice machine stopped working. I checked the solenoid valve for the ice machine and it works, as does the water dispeser in the door. The teeth in the ice...
First off is the water filter bad and or do you have one...if not and it is good...then you have pretty much diagnosed the problem correctly...as you said the old Ice maker gears turn and when they make a complete revolution they engage a trigger which signals the water solenoid to dispense water to the ice maker...another test is to fill the ice maker manually and see if it freezes (test the temp of the freezer...if it is not cold enough the ice maker will not work)...if ice is made (generally under 4 hours ) and it is not dumped...you need to replace the Ice maker...around $30 to $50depnding on brand and where you buy it...I shop Marcones Appliance parts the appliance repairman's friend...good quality cheap prices.
Good Luck I hope this helped...please rate me ...the Fang.
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
ghdh
1helpful
Ice maker not filling with water
I have a model KSRG25F and found that the solenoid that controls the water to the icemaker was not working. I tested by switching the water dispenser connection to the ice maker coil.
And then had the wife push the water fill in front of the fridge. I had aready changed out the control board in front because I didnt have the flash codes or solid led when simulating door closed. the parts is about $55 and hope that does it. Good Luck
35helpful
6answers
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
