Hotpoint HSS25GFP Side by Side Refrigerator Logo
Posted on Feb 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot detach old water line from indoor water container.
I have a hotpoint side by side hotpoint refridge with a broken water line. I am unable to detach the water line from the indoor water container. It looks to be glued or welded somehow. I am able to buy a water line from GE but there are no instructions. I thought about splicing the water line but there are no splicers made to fit the special made water lines. How do I detach the water line?
Anonymous
Level 3:
  • Master 833 Answers
  • Posted on Feb 25, 2009
Anonymous
Master
Level 3:
Answers
833
Questions
0
Helped
518869
Points
1606
Often, the service part does not fit the same way that the factory item does. Examine the new tube and determine the dimension of the interior. Chances are that it will slide over either the stub of the water line or, if you twist off the line, you'll be able to install it in place. In certain cases, the old line is shrink fit over the nub of the container. You'll either have to break it or, better yet, **** it to get it off.
1helpful
I cant find the filter on my hotpoint no frost refridg.number csx22gr where is it.
your model number doesn't come up.if it's an older machine some didn't come with water filters,you had to add an inline filter on the copper water line,you would run your copper,go down the cellar or behind the machine,cut the copper and the filter connects in between the copper where you cut the line.if you do have a filter it could be in the fridge section top right side or down in the bottom kickplate.i found your model the a was missing after the b baww.it doesn't show a filter,this is an older unit,check behind or in basement,wherever the water line goes and see if there's a filter added into it,if not you can cut the copper and add a filter yourself.home depot sells them
http://www.homedepot.com/p/Whirlpool-In-Line-Refrigerator-Water-Filter-4378411RB/202204720#.Ug7jNxXD_X4
1helpful
Hotpoint refridger ice maker not despencing ice or water
my ice maker stop making ice there is ice cubes in the tray but the ice maker does not dispence the ice
1helpful
I need to install a new fitting (part # 2196157). That is the fill tube on the ice maker on our whirlpool refrigerator (model number ed2fhgxkt00) The water line is already detached since the threaded part...
Yes that s it. You may have to tug a little to get the old one out as sometimes the foam will try to hold them in a little tight.
One thing to check before you connect your water line. Take a look at the end of the water line for a minute make sure that no water is going to drip out of it. If it does you may as well replace the valve because that is going to plug the tube with ice and possibly damage the ice maker.
Reconnect your water line and flip the ice maker on and the water should start to flow shortly. That s it.
Thanks for asking.
Ice maker works but no water coming out
if the water tank is frozen, i would raise the temp on the fridge for a while but, Im sensing an issue with the water valve assembly. may be stuck in the closed position.
Ice maker
disconnect the power wires from the valve, if it still fills with water, I would say you have a stuck valve. just because its new, doesnt mean its going to work.
2answers
Replacing Auger in ice maker
Kim There are two Screws Holding the Complete Ice unit in Place,After Removing it it unpluggs inside the freezer,It would be advised to Replace the whole Unit ttech
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
