Is the lid lock tang on lid broken.
2.9 Lid Lock
The Phase 7 Washer uses the same lid lock that is used on
the Phase 6 series 11 & 12 machines. The difference being is that the lid is now locked for the entire cycle. When the lid is locked the Lid Locked LED will illuminate. Once the spin
has completed, the lock will release and the lid can be
opened. To open the lid during the cycle the
START/PAUSE button must be pressed, the machine will
come to a halt, and the lid locked LED will extinguish.
If the lid is left open, the machine will be unable to lock the lid
and the cycle will be halted. The machine will play a tune
and the lid lock will flash until the lid is closed and START/PAUSE is pressed.
• If the lid-lock fails in the closed position, the locked lid can be forced upwards and out of the
lock. Note: This is the only time in which we would recommend doing this.
• If the harness is damaged, the complete lid lock assembly will need to be replaced.
If the power supply is cut during the spin cycle, the machine will keep the lid locked until the rotor has ceased to turn (3 to 10 secs). Only then will it release the lock. The motor is acting like a generator and allows the lock to stay energized under the bowls inertia.
