I just installed a new Simon XT in my home. Pretty straightforward except for two issues. 1. When I disarm the system (and yes it disarms and says disarmed, and ok), then pass through a motion sensor area, the alarm goes off and say motion sensor. How do I get the motion sensors to not activate the alarm when the alarm is off? )I know how to bypass and unbypass, and that is not the issue) 2. When the sensors set of the "disarmed" alarm, the machine calls my cell phone (which I programmed it to do) 3 or 4 times before declaring a communication failure. My cellphone touch tone keys won't let me acknowledge the system with the * key. Any ideas?
SOURCE: goes off even when disarmed!
This is from page 19 of the Simon3 manual found here:
http://www.safemart.com/manuals/simon3.pdf
It appears you have the "CHIME on Motion" enabled. Follow the Option 41 steps to disable it.
Option 41 - Voice Chime
The panel will verbally announce which chime sensor has been tripped if the chime
feature is on.
Add enables chime voice.
1. Open panel cover. Panel announces, Use numbered keys to enter ID.
2. Enter Access Code using the numbered keys. Panel announces, Please select from
Start Menu.
3. Press Add from the Start menu. Panel announces, Select from main menu
4. Press Option #. Panel announces, Option 1, press again for next option or done to
select.
5. Press 41. Panel announces, Option 41, press again for next option or done to
select
6. Press DONE. Panel announces, Option 41 is on.
Delete disables chime voice. The panel will not announce which chime sensor has
been tripped but will still chime 2 times for doors and 3 times for motion sensors when
a given sensor is tripped.
Start Menu.
3. Press Delete from the Start menu. Panel announces, Select from main menu
select.
delete
6. Press DONE. Panel announces, Option 41 deleted.
SOURCE: GE/ADT DIY system will not accept master code./beeps twice/2 hour
Press the system status button on the top right and the system should announce the error message that is keeping it from accepting the code.
