Computers & Internet Logo
A
Anonymous Posted on Mar 17, 2013
LG flatron L1918S Out of Range 68,5kHz/85Hz
2 Related Answers
Anonymous
  • 208 Answers
  • Posted on May 20, 2010
SOURCE: Flatron L1919S (Black) LCD Monitor: Is my LCD monitor, LG Flatron L1918S, good enough ...
You should google this. After looking myself i have seen that it should play HD movies without a problem.
masudcht86
abdullah almasud
  • Posted on May 22, 2014
"Thanks for your nice post . I hope I will see this type of post again in your blog" .
I have a LG Flatron E2750v Monitor connected with a standard cord between the monitor In the center of the screen it reads: D-Sub out of range 68.5Khz/85Hz VGA Port or Power saving mode HDMI Port
Hi, that message indicates that your video source is providing an unsupported video resolution , please check in settings that video output resolution is no more than 1920 x 1080 @ 60Hz.
Also remember to verify that HDMI is selected as input source at monitor.
My monitor it turn on and off itself
Try connecting your monitor to a different computer.
If it still turns on and off, the monitor is failing.
It needs to be replaced.
I have a LG Flatron EW224 computer monitor. It was working great but one day the screen went blank and reads in the center of screen: D-Sub out of range 68.5Khz/85Hz. Does anyone know how to correct this...
This is usually due to your computer Video resolution being set to a setting out of the supported range of your monitor, Lowering the computer video resolution should solve this issue.
Out of range 68.6khz/ 85hz
At 85 hz refresh rate can damage you monitor, most LCD monitor are not recommended to go higher than 75Hz. You should set you PC video resolution to the native resolution of the monitor:
1280 x 1024 @60Hz.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
2helpful
2answers
I get (D-sub out of range 53.6 k hz / 85 h z) how do I fix this?
this is a how to video on how to fix the video out of range error.
What is default monitor screen setting LG flatron e700sh
1280x1024 resolution
I would try using a 60hz refresh rate though it does state the monitor will support up to 85hz
1helpful
2answers
I have upto now been using my lg Flatron L1919S monitor as a tv with a separate tuner. Today i replaced it with an lcd tv and was going to use the monitor for my computer. However when i connected it up...
It means your PC video resolution is too high for the monitor to display, you need to set your PC video to the native resolution of this monitor, 1280 x 1024 @60Hz.
Start up in sfae mode (hit f8 while booting up), select VGA support, then right click on desk top/properties to bring up display property/setting. set the new resolution , reboot.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
1helpful
2answers
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
