Is there away to test coil ? have remove wir from kill switch still no spark
There are only 4 parts to the 2-stroke Mantis ignition system: the spark plug, the "kill button", the flywheel with embedded magnets, and the coil with integral plug wire. There are no "points" to clean or refurbish. If you've tried a new spark plug, unplugged the wire leading up the handlebars, and the magnets on the side of the flywheel are strong enough to attract a screw driver blade, then it must be a bad coil. That's all it could be. End of story.
Cruising the internet I see where these Echo coils go bad all the time. You can order the coil, but if the machine hasn't run in several years the carb will also need cleaning. So one thing leads to another. The gear box grease also needs replacing each year. What I'm trying to tell you is these are disposable tillers and due to length of time, incomplete care/ storage, ....whatever, this one's time is up.
Sorry.
started up after being stored in a warm room all winter, but won't stop unless I remove the spark wire
