Had this computer for a few years, when I downloaded Google Chrome it started acting glitchy and Chrome would crash while I was browsing. Recently started having problems with the battery, tried taking the battery out and now shuts down every time I unplug it. Any troubleshooting that might help? Thanks.
SOURCE: Dell Inspiron E1505 no sound in web browser
Thanks for the response damanpreet_c.
The volume button on the video and of the computer volume control are all to maximum.
I tried watching the same videos on other computers and they work fine.
However, Dell computer which used to play Video X through browsers A,B,C and had sound out now doesn't have any sound out. The same Video X after downloading on the same computer has the sound out. The same Video X without downloading through browsers A,B,C have the sound on other computers. Would this imply that on the Dell computer, the browser has some issues with the sound drivers in playing files?
Thanks again for the response.
Viraj
SOURCE: Dell inspiron 1545 laptop and the same webcam problem.
open your my computer, click on "c" the system will tell you the information is hidden, click on the link and open up the operating system and look in the drivers or there in C and se if you can find you web cam driver, when you find it you might have to force the opening of the driver to install, and once you do that plug your web cam in and see if the system see's it and installs the drivers for the cam, if you installed the driver origanally witht he web cam installed you will have to remove the web cam and unistall the driver and re install it and then plug the web cam back in, and that should help correct the problem.
SOURCE: Dell Inspiron 1545 power adapter not charging machine
Just call Dell, don't take it back to Best Buy or anything (that's where I got my Inspiron 1565). They will put you through a couple troubleshooting items and decide whether it's the AC adapter went bad or if they have to replace your motherboard. It's all free since they have a 1yr hardware warranty.
SOURCE: dell inspiron 1545 start up problem
try press F12 when you see the DELL Logo, if it still goes to BIOS you need to replace keyboard
SOURCE: laptop dell inspiron 1545 no power up
Hello anourkhader
When was the last time you used it, and were there any problems? To find the solution to this problem is a matter of elimination. You should check the following:
Step 1 - Power
- Try an alternative power adapter
- Try plugging in your laptop to an alternative power supply
WARNING - BEFORE PROCEEDING, PLEASE FOLLOW THE FOLLOWING SAFETY PRECAUTIONS!
1. REMOVE THE POWER ADAPTER FROM YOUR LAPTOP
2. REMOVE ALL PERIPHERALS
3. WEAR A WRIST-GROUNDING STRAP, AND CONNECT IT TO AN UNPAINTED, METAL SURFACE. IF ONE IS NOT AVAILABLE, TOUCH AN UNPAINTED METAL SURFACE TO DISCHARGE ANY STATIC FROM YOUR BODY
Step 2 - Remove and reset basic hardware items
Remove and reseat the items mentioned below in the order they're mentioned:
- AC adapter
- Battery
- Memory
- Hard drive
For instructions on how to do this, please refer to your user manual. If you no longer have it, you can download it from here: http://support.dell.com/support/edocs/systems/ins1545/
If after following the above instructions, your laptop still doesn't turn on, I would recommend that you contact Dell customer support, which you can do by following this link: http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?
I hope this helps. Please feel free to contact me if you require further assistance.
ajblaj
It also says it's not detecting the battery. And I don't think there's any antivirus software on here, either. (It's actually my mom's laptop, we got a virus on it before and now she's afraid to download ANYTHING. Including antivirus software -__-)
