Clothes not drying - drum heat is cool - good, strong hot air exiting vent - vent, duct clean and clear - lint trap cleaned between loads - good amount of lint clumped behind lint screen area through - unable to access to clean
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
SOURCE: Whirlpool Model LE7010XSNO. No Heat After Lint Cleaned Out
Those are likely possibilities. Also check the wiring for disconnected or burned terminals especially in areas that get hot. The element comes out easily to visually check it for breaks. If that's OK I'd look at the safety thermostat.
SOURCE: Clothes not drying even after 4 cycles
you have to check your dyer vent hose and vent pipe to outside for any restrictions. #1 problem for extented drying time. it like having a backed up sink
SOURCE: not drying
It may not be your heating element. Your dryer lint vent pipe out the back of the machine or maybe out the
side may be plugged. You have to pull the machine out and clear
that pipe or rebuild it out to a soffit vent or static vent if it is in
the attic, or out through your crawl space. This will make a huge
difference. If that hot air and moisture doesn't get out of the
machine it just goes back into your clothes.
Good luck!!
SOURCE: maytag gas dryer taking too long to dry clothes
Not too familliar with the gas temp either, but you should definitely take your lint filter out and clean it with soap and water. If you use dryer sheets, they can leave a clear film on your filter and it can be just as bad as a filter full of lint. Try this out, if it works, clean your filter periodically with soap and water to remove the chemical buildup.
