MY WASHER IS FLASHING F11
"F11" is a Serial Communications error. In a nut shell, the Central Control Unit (CCU) isn't communicating properly with one or more components. The following link explains:
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
This problem can be attributed to wiring, a bad connector plug, or the CCU itself has failed. You can attempt to reset the CCU by unplugging the washer for at least 30 minutes. Sometimes these error codes are erroneous and a reset will correct momentary glitches. If the error code reappears following a reset, you have a problem. Please read through the link provided. If you still require assistance, please let me know.
If you're looking for technical data about the error code, there is a tech sheet affixed to the interior cabinet wall behind the lower panel under the door. There are three torx screws under the front edge of the panel that you will need to remove. With the screws removed, the panel will drop down then off.
If you are looking for a User's Manual that explains the operation of the washer, you can go to Managemyhome.com and register (this is a FREE service). Once registered, look under the "Home Managers" heading and click on the "Owner's Manuals" link. Follow the instructions on the next page and your owner's manual will be available in a downloadable .pdf format.
If you require additional assistance, please let me know. I hope this helps you.
