Question about HP PL5060N 50 in. Plasma HDTV
Set shuts off by it self
You watch tv and it shuts off. Let it sit turn it back on after a wile it shuts back off
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
NO you have an over heating problem, I see a bunch of Boards and Proccesors, But NO fan in this TV CHIPS get hot they need more then a heat sink that just spreads the damage
Posted on Mar 22, 2013
    Top Expert:
  • HP Master
  • 55,370 Answers
The symptom you describe indicates the internal power supply is failing
Posted on Mar 19, 2013
6ya staff
SOURCE:
My 1998 hitachi projector tv just randomly turns its self off and no matter how many times I push the power button it won't come on it does nothing no flash no noise no lights but after 15 to 20 mins...
The first thing possible is bad solder connections in the power supply or elsewhere.
Most of these sets with the back off have several green LED lights on the board and a red one.
The red one should be on all the time. What can be done is sit with back off and watch the Green ones--at the moment it shuts off does one go out first or last----each is tied to a voltage source in the set--it will point to where the problem is coming from---ancient self check feature that usually works well.
Another tactic you can use is if when it happens unplug it for a few minutes--I used to hook these to a wall switch so could kill power for a few minutes and try to turn back on--this would indicate a problem in the start up circuit in the power supply.
Tricks of the trade from working on lots of these sets---it would be easy to find if it just did not turn on at all.........
May 29, 2012 | Hitachi Televison & Video
I have a rca d52w23 while i was watching tv in shut off and there was like a smoke smell I mean I turn it on and it shuts off by it self is it worth fixing it and what can cause this problem
Where there is smoke something burned--unplug set for safety and if curious open rear cover and look at boards near rear of set for a burnt part--that will usually determine if worth fixing or not.
Apr 26, 2012 | RCA D52W23 52" HDTV CRT TV
Our Mitsubishi projection tv went out one day. When we went to turn it back on all it does is blink the green light for a few seconds and then shuts off. What could it be? Where can we look to see where...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
Aug 09, 2011 | Mitsubishi WS-65807 65" Rear Projection...
When I turn the tv on the power light goes green for a couple of seconds then it shuts off and the picture never comes up.
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Jun 03, 2011 | Mitsubishi WS-65315 65" Rear Projection...
I was watching a movie on the dvd, then after the movie was done I turned the tv off. Two hours later, I was turning the tv on to watch a football game but I got no picture, all I got is ...
Unplug,replug tv an hour later.Tv it now resetting it self back to factory setting.Tv still have the same problems.The T-CON board is dead.This board is the board sit right at the bottom center of the LCD panel screen.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Sep 21, 2010 | Sanyo DP42848 LCD TV
I was watching it and it just shut off when i turn it on 3 seconds later it shuts off again
this set has a self diagnostic feature:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
If this has been helpful I would appreciate a vote from you here; if you need direct help:
etower.766@netzero.net
Aug 14, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My tv plays about 1-1/2 hours then shuts down
YOU WILL NEED TO REPLACE YOUR PROJECTOR LAMP #BP96-01472A AND THIS SHOULD RESOLVE YOUR ISSUE.
HOPE THIS HELPS
Jul 07, 2009 | Samsung HL-S5087W DLP TV
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
Tv shuts off while watching
replace EHT (extra high tension) transformer
Feb 07, 2007 | Philips TS3661C 36" TV
Tv wont turn on
You probably have a bad flyback transformer (high voltage). You might want to get an estimate to find out if it is worth repairing. Stargazer
Jan 20, 2007 | Sanyo DS31590 31" TV
HP PL5060N 50 in. Plasma HDTV Logo
51 people viewed this question
Top HP Televison & Video Experts
Ekse
Thomas F. Schneider
Edward Easley
Edward Easley
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
