Canon PowerShot EOS D60 Digital Camera Logo
sydney scott Posted on Mar 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to get a remote system working on my D60?
What are the perimeters (settings) to make it function.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Mar 19, 2013
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10441081
Points
622693
You need to set the release mode to one of the remote modes. The quick-response remote mode fires the shutter when you press the shutter release button on the remote. The delayed remote mode gives you two seconds to hide the remote behind your back before the shutter fires.
For full details see the "Self-Timer and Remote Control Modes" section of the manual (begins on page 55 in my copy).
2answers
How do I set it up on my Nikon D60 to use this remote?
I assume you're referring to the ML-L3 infrared remote?
Select Release Mode from the Quick settings display. Select Quick-response remote. This will make the camera take a picture when you press the button on the remote. Well, almost. The same focusing and exposure metering delays occur as if you'd pressed the shutter release button.
You can also use the Delayed remote mode for group pictures. This gives you two seconds to hide your hand behind your back before the camera takes the picture.
By default the D60 will time out after one minute if you don't press the button on the remote. Custom Setting #17 allows you to set a longer interval.
Jun 17, 2010 • Cameras
My Nikon D60 monitor is dark...no image preview, however, playback for viewing pictures taken works fine. I use the viewfinder for taking pictures, but wonder if I've done something to turn off the monitor...
No, you have done nothing wrong. The D60 does not have the preview function on the monitor like the compact digital cameras. Nikon gave that function a name. It is called 'Live View'. The newr models like the D90 do have that feature. You can read further about your D60 here: www.digitalcamera-hq.com
2helpful
Need instructions on wireless remote for D60
Set the shooting mode to Delayed-remote or Quick-response remote.
Look in the camera manual under "Shooting Modes."
2helpful
Remote not functioning
Make sure the shooting mode is set to one of the remote modes.
Look in your manual under "Shooting Mode."
2helpful
Trying to set up a Zeikos ZE-WRL3 with a Nikon D^) and it won't work could soeone guide me through it?
I assume you mean a Nikon D60? I'm also assuming the ZE-WRL3 is FULLY compatible with the ML-L3.
Set the release mode to one of the remote modes. Quick-response takes a pic as soon as you press the button. Delayed-response waits two seconds, allowing you to hide the remote behind your back. Either way, the usual caveats about focus and metering apply.
There should be a section in manual titled "Release Mode" or "Shooting Mode" that gives full details.
1helpful
I have a Nikon D60 and when I take a picture, there is no image. Just a white picture. Can someone please help.
Your exposure is set way too high maybe?,
If you are using the manual function then turn the round slider located right beside the ae-l and af-l button to the right until picture sorts itself out.
Or use the twist function settings ontop of the camera and set it to AUTO.
If neither of these works then try going into the menu and selecting reset, do not worry this will not delete your pictures, then then try it out.
Hope it works and you can get back to taking some good pictures!
1helpful
VEHICLE WONT START
Section 13-11: Anti-Theft System, Active 1998 Windstar Workshop Manual DESCRIPTION AND OPERATION Anti-Theft Alarm System NOTE: The system immediately monitors the ignition key lock cylinder upon removal of the key from the ignition. It is not necessary to arm the system for ignition key lock monitoring.
The anti-theft alarm system:
  • protects the vehicle from unauthorized entry into the passenger compartment, engine compartment and cargo area.
  • monitors the status of the ignition key lock cylinder.
  • is controlled by a remote anti-theft personality (RAP) module. The remote anti-theft personality module also controls the electronic door lock functions. Refer to Section 01-14B for more details.
  • when armed, detects unauthorized entry into the passenger compartment by using an input from the GEM module regarding the state of the door or liftgate (open or closed).
  • protects the engine compartment with a hood switch which is located on the LH cowl vent panel and is part of windshield wiper motor wiring (17A477) .
  • triggers an alarm if the ignition lock cylinder is forcibly removed from the steering column.
Once triggered, the system responds by:
  • flashing the low beam headlamps, the parklamps, rear lamps and the alarm indicator warning light emitting diode (LED).
  • sounding the horn (13832).
  • disabling the starter circuit until the system is disarmed.
Remote Anti-Theft Personality Module
  • The remote anti-theft personality module is located behind the instrument panel (04320).
  • It contains a radio receiver that receives the RF signal from the keyless entry remote transmitter (15K601) through the alarm and lock system antenna (15603) and sends the appropriate command to the power door locks, the horn relay, or the generic electronic module.
  • The remote anti-theft personality module is equipped with an internal backup power supply which holds the programmed code in memory in the event the vehicle battery is disconnected.
Remote Anti-Theft Personality Module Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove radio. Refer to Section 15-01 .
  1. Remove lower instrument panel center finish panel. Refer to Section 01-12 .
  1. Lower glove box.
  1. Remove two remote anti-theft personality module bracket retaining screws.
  1. Disconnect electrical connectors and alarm and lock system antenna (15603).
  1. Remove remote anti-theft personality module and bracket.
  1. Remove remote anti-theft personality module from mounting bracket.
Installation
  1. To install, follow removal procedure in reverse order.
  1. Tighten remote anti-theft personality module bracket retaining screws to 6-8 Nm (54-70 lb-in).
Components The system is composed of the following components:
  • remote anti-theft personality (RAP) module with integral antenna
  • alarm indicator LED
  • door lock cylinder switch RH, door lock cylinder switch LH
  • liftgate door lock cylinder switch (220A40)
  • hood switch (part of windshield wiper motor wiring (17A477))
  • ignition lock anti-theft switch (19A438)
The following vehicle components are also used by the anti-theft alarm system:
  • generic electronic module
  • power door lock switch (14028)
  • door open warning lamp switch (14018)
  • autolamp relay (14N089)
  • horn relay and bracket (13853) and horn (13832)
  • low beam headlamps
  • rear lamps (13404) and parking lamps (13200)
  • starter relay
  • door lock relays
  • keyless entry remote transmitter (15K601)
Disarming an Untriggered System NOTE: A perimeter alarm will "shut off" after 165 seconds, but the system is still triggered and is not disarmed.
An armed but untriggered perimeter anti-theft system can be disarmed by one of the following four events:
  1. Unlock the doors by pressing the keyless entry remote transmitter (15K601) UNLOCK button once.
  2. Unlock any door with a key.
  3. Turn ignition switch to RUN or ACC.
  4. The remote entry PANIC button will disarm the anti-theft system only when the perimeter alarm is triggered and sounding.
System Triggering NOTE: Although the remote entry PANIC alarm is not associated with the monitoring of the vehicle, the user will frequently say that the theft system was triggered when actually the keyless entry remote transmitter PANIC button was inadvertently pressed. A panic alarm will not flash the THEFT indicator.
The alarm can be triggered by the following events if the system has been armed and has not been disarmed first:
  • Open any door or liftgate.
  • Open the hood (16612) (if the hood was open when the system was armed, it must be closed before it can trigger the alarm).
  • Dislodge the ignition key lock cylinder.
  • The anti-theft system may be triggered inadvertently when the module is disconnected and then reconnected. To avoid inadvertent alarm triggering, disconnect the smaller 22-way connector first.
When the system is triggered the perimeter alarm will operate as follows: The remote anti-theft personality module will pulse the following outputs at approximately 1.3 Hz, 50 percent duty cycle for two minutes 45 seconds for North America. NOTE: Other perimeter alarms can be programmed for the system.
  • parking lamps
  • horn
  • THEFT indicator
The perimeter alarm can be retriggered, after a perimeter alarm has sounded for 165 seconds. After a perimeter alarm has timed out, if any trigger input is first seen as normal and is then seen in its trigger state, the perimeter alarm will be retriggered. The perimeter alarm can be triggered a total of three times between an arming sequence and a disarm event. An active panic alarm will be deactivated when a perimeter alarm is triggered (a perimeter alarm overrides a panic alarm).
12helpful
How do i connect my wireless remote to my d60????
In the Shooting Mode menu, change <from either Single or Continuous or 10Second self-timer> to 2S (two seconds) Remote or immediate Remote -- there's an icon that looks like your remote. Then get in front of the camera (lens cap removed already) and point the remote to the IR receiver on the front of the camera and click the remote button ... it will take the shot immediately or after two seconds (depending on what you specified).
The shooting mode doesn't seem to stick -- if I turn the camera off and then on, it's gone back to how it was previous set and I have to set it to remote again.
My bigger problem was I thought (guessed, since there were no instructions!) that I had to press the self-timer function button before clicking the remote -- but doing that kept resetting my shooting mode back to 10 seconds on SELF TIMER (taking it off of REMOTE mode).
29helpful
3answers
Using the ML-L3 with the D60
Got it! It's on page 54 of the manual (mine anyway).
Choose release mode from the Quick settings display.
You have a choice between:
single frame (default)
continuous (burst mode)
self-timer
delayed remote (using the ML-L3)
quick response remote (using the ML-L3)
I just took 4 self-portraits using quick response. And deleted them straightaway!
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
