Resetting error code c970
SOURCE: Error code in E studio 150
Hello! I did it and it worked perfectly.
I entered the SIM mode : CLear - Auto- Clear - Auto- then I pressed 14 -Start- Clear and then , the machine automatically warmed up and came to ready...Please, How can I be a copier Tech? I'm so eager to learn that. LET ME KNOW SO I CAN HELP OTHERS. THANKS SO MUCH...
SOURCE: toshiba e-studio 232 code C970
C970:
HVT or charge corona.
Remove main charge and trans/sep. coratron units and check --- make sure wires are not broke, clean grid, clean canals of units.
Replace and part needed.
If coratron units are fine --- replace HVT ( high voltage transformer).
SOURCE: toshiba e studio 350
C970 indicates charging issue. Need to check the T/S block and main charger for deform/broken wires.
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
For error code C44, it indicates Heater abnormality.
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
If happen again, then u need to check the thermistor. Replace it if necessary. If themistor replaced but still happen again, then u need to proceed to check themostat--> heater-->Mainboard-->Switching regulator.
