Canon PIXMA  iP3300 InkJet Photo Printer Logo
Derek Abrahamse Posted on Mar 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to print a test page - Canon PIXMA iP3300 InkJet Photo Printer
Anonymous
Level 3:
  • Canon Master 32,281 Answers
  • Posted on Mar 19, 2013
Anonymous
Canon Master
Level 3:
Answers
32281
Questions
Helped
7907304
Points
102259
Click Start - Printers and Faxes - right click on the printer - click Properties - click Print Test page.
Testimonial: "Salutations Chris Hingee! Thanx for the heads-up on my Canon Pixma iP3000. The test worked fine and now know I need to load the new Drivers for the printer. Great and much appreciated. Derek Abrahamse"
2answers
Just installed a new printer after running the test the last instruction,click on which one the page turned out none of the pictures are there to select one. I just need to know what the graphics are
depending on the make , model and if the printer prints both sides
when you go to print it will say
print all pages
or print pages--and you type in the page numbers you want printed
There is also a setting that says print all odd pages or print all even pages
May be you should go to the manufacturers web site and down load the user manual for that printer
1helpful
NEED TO PRINT A TEST PAGE MANUALLY FOR CANON PIXMA IP3000
Click on Start - Printers and faxes - right click on your printer - Click Properties - then click on Print test Page.
2answers
The printer cuts off the top part of the document when printing. Is this a margin issue?
Yes, most likely your application's margin settings are incorrect. Try printing a test page - NOT from the application. If this is Windows, go to printers in control panel, right-click on the subject printer, choose Properties, then click the Print Test Page button. You should get the standard Windows printer test page with the logo at the top and all the printer specifics below. If the test page is also cut off, look around in the HP-provided software for any margin and/or page size settings that are incorrect, such as A4 paper when it should really be Letter size.
My Officejet 4315 All-in-One is printing very very slow How do I fix this problem? I have restarted it and unplugged then replugged it and have restarted the computer and it still prints really really...
The very first thing you need to do determine whether the issue is in the Hardware or in the Software for that on the printer .
1. Load plain paper in the tray.
2. Press the Setup button
3. Press 2 to select Print Report
4. Press 4 to select Self-Test Report . The self-test page prints.
Measure the time (in seconds) it takes for the test page to prints.If the test page prints in less than 60 seconds , this is normal print speed and you do not need to troubleshoot.If the test page prints in more than 60 seconds , go to the next step.
Important ;
Some products print faster than others. If the test page exceeds 60 seconds, and other documents you print typically take as long, the print speed is normal. Troubleshoot this issue only if your product is designed to print faster than about 60 seconds a page or if printing is slower than usual.
***** IF THE PRINT SPEED IS MORE THAN 60 SEC.
Check the power supply. to check the power supply you need to follow these steps.
1. Turn the product so that you can access the rear side.
2. Unplug the power cord from the back of the product.
3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
4. Plug the power cord directly into a wall outlet.
5. Print and time a self-test again.
If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet. If the test page takes significantly longer than 30 seconds to print, continue to the next solution.
CHECK THE CARTRIDGE COMPATIBILTY.
Incompatible cartridges can cause the slow printing problem.
Which cartridges you use depends on your country or region. To check the cartridge compatibility you can go to this site (for hp printers) http://www.hp.com/buy/suresupply and check The number on the cartridge label must match the numbers listed on HP SureSupply.
PERFORM A RESET.
1. Press the Power button and turn off the printer.
2. unplug the power cord. Disconnect the data cable(USB,Ethernet depending upon the the product set up). wait for 30 secs. reconnect all the cable and than try to print a test page.
if these steps resolves the issue than you dont need to continue troubleshooting or if the issue persist than Replace the Power supply for your product.
4helpful
2answers
Is there a counter for pages printed on my 1320n
No, the page count is not on the test page. You need the configuration page. Press the GO button and hold for 5 seconds. The yellow light will come on and you can release.
How to print configuration page hp officejet g55
Printing a self-test page Method one: Print a self-test page from the All-in-One control panel
  1. Press the Menu button.
  2. Press 3 or use the arrow keys to scroll to Print Report , and then press the Enter button.
  3. Press 5 or use the arrow keys to scroll to Print Report , and then press the Enter button. The self-test page prints.
Method two: Print a self-test page from the computer
  1. Click Start and click Printers and Faxes .
  2. Right-click the appropriate product, and then click Properties .
  3. Click Print Test Page . The self-test page prints.
4helpful
3answers
Where is the serial number on an HP Officejet J6480 All-in-One printer
Usually the serial number can be found either in the back or in the bottom of the printer.
If your printer is working you can print a self diagnostic page which would have the serial number.
To print the Self-Test Diagnostic Page
• Device control panel: Press Setup, select Print Report, select Self-Test Report,
and then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print a Test Page.
12helpful
3answers
Hp 1320 prints blank LOSER SPAM ALERT 1-800-532-4187
My HP 1320 printer is printing blank pages and it will not even print test pages etc
12helpful
2answers
Number of pages my printer has printed
You need to print a self diagnostic page. On that page will be listed the number of pages printed from trays and accessories.
• Control panel: Press Setup, select Print Report, select Self-Test Report, and
then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print Self-test
Diagnostic Page.
• HP Printer Utility (Mac OS): Click Device Information from the Information and
Support panel, and then click Print Configuration Page.
Thanks and please take a moment to rate this as fixya.
Printing Test Page
you probably need to align the print cartridges. you can usually do that through the advanced printer oprions
old marine
old marine
ZJ Limited
ZJ Limited
