I charged my blueant S4 in the car and on the laptop. The device is telling me it is fully charged but won't work unless connected to the charger.
Is this a battery or charging problem?
The simplest way to repair it is to take it to a local cell phone repair shop and let them do it for about $35 to $50. I would determine first if that is worth the phone to do so.. If not, it may be more economical for you to just buy another phone.
Parts for this particular device are not easily found. And, you can't just call up Samsung Customer Support and say you need this part. Parts are usually sold through 3rd party cell phone repair centers only.
The schematics for this device are not readily available and there are no known repair videos online for you to follow.
REASONS OF SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
The main reason of Samsung Galaxy S4 not charging- grey battery problem is a shorted charging port. There may be several reasons for it such as sometimes dust entered into the charging port and causes this problem. Sometimes the bar across the center of the charging port gets bent.
SOLUTIONS TO FIX SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
Method 1 If your Galaxy S4 falls and you start to face Samsung Galaxy S4 not charging- grey battery problem, then take a pointed wooden toothpick, a magnifying glass and a strong light and see carefully if any bar across the center of the charging port is in the center and not bent to touch one of the sides of the shell. If you find that it is bent then straight it using the toothpick point carefully.
Method 2 Look for the dirt into the charging port that it may pick up from anywhere. Take a thin needle and gently insert it in the charging port to take out the large piece of dirt from it. But you have to be very careful so that you do not make any damages of the charging port. You can do this by using a can of compressed air or dust/hair blower that will blow out the small dust particles from your phone's charging port.
Method 3 Some users reported that they have found solution of the Samsung Galaxy S4 not charging- grey battery problem by taking out the battery from the phone , insert it into another Samsung Galaxy S4 ,and then again put it in back.
So follow these steps to get rid of Samsung Galaxy S4 not charging- grey battery issue.
Well.. The blueant S4's battery is irreplaceable. If your device is still covered by the warranty and you still get hold of the receipt, well call them and ask for assistance
System Power State S4. System power state S4, the hibernate state, is the lowest-powered sleeping state and has the longest wake-up latency. To reduce power consumption to a minimum, the hardware powers off all devices.
Have you done all the hardware (Toshiba) and software updates ( Windows) to your system? Did you change anything in the BIOS? Please answer so I can assist.
Unfortunately you have a defective unit. I have seen several of these same units with the same issue. Return the item and get your money back. Thanks for visiting FixYa.com. Have a great day!
I know this link is old but the same problem happened today to my new device a s4 I tried to update the device and the update program stopped halfway through.I tried this several times and each time after the program stopped dead halfway through I pressed the cancel button and followed onscreen prompts, I then noticed that the device would not respond and was just a dead piece of kit.It seems that it was still in DFU mode(update mode)and needed the software to install an update to get it to work again. It seems that the problem could be how the device reacts to the type of motherboard I have on my PC.BluAnt mention issues with ASUS boards on their site wioth another device. at the office. So after dozens of tries to get the s4 to update using the downloaded updater from Blueant, I went into Windows Explorer and found the directory 'BluAnt Universal Updater' I copied the directory to my memory stick and then took it home. On my PC at home I copied over the BAUU directory. Downloaded and ran the updater program ....and.....it installed the update within a couple of minutes. It seems that the update program downloads the update to a directory within the BAUU directory and also places a 'Backup' directory there from your device, so if a problem occurs you can tell the updater program to update from a file on your hard drive.Please pass this 'fix' on.
