You can get the master reset code for your Nokia 5130 from the site
Unlock-Free.com . Which can be used to reset your phone so that you can access your phone without the old security code. After resetting your phone, if you need you can set a new security code to protect you phone. To get the master reset code provide the IMEI number your phone.
SOURCE: Resetting Security Code
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
SOURCE: forgot my security code for nokia 3110c,imei 358672/01/0225658/4
Is the password was a Security password, or the PIN/SIM password?
Regarding with your problem, you better call your network provider for
this issue, they can assist you and remotely unlock your phone.
Hope this initial info helps.
micro~
