I know for sure that the settings at which my camera is telling me under exposed is in return actually over exposed. i shot a full role at the settings that my camera said i should be shooting at and sure enough they returned completely washed out for the most part. i'm a real hands on person and would like to fix this issue myself.
Just to be sure, do you have the film speed set correctly?
yeah i'm pretty familiar with the speed settings. i just know that with my lens pointed towards the sun on 3.5 and 1/60 shouldn't be a green light. Speeds i normally would shoot at that would be in the greenlight range are now completely red minus' in my light meter.
Okay, just wanted to make sure. I know I've gone through entire rolls of film on my FMs with the wrong speed set. I hope you haven't been pointing the camera at the sun very much. That's a good way to burn out a light meter.
Do you have another camera or light meter for comparison? Can you tell whether the FM10 is consistent in its overexposure?
as of late it has been pretty consistent. the roll i got was overexposed for sure. i unfortunately do not have another camera or separate light meter. i just know from past experience that it should be saying everything is underexposed at the settings i normally shoot at.
Stretching now, but check the battery contacts and make sure they're clean. Other than that, I don't know what to say. If it's not the battery and contacts then the meter is faulty. Unless you want to take the camera apart to get to the meter...
i will try this as soon as i get home. if not i guess i'll just stick to the sunny 16 rule. do you know of any cheap, reliable light meters?
Sorry, I haven't shopped for light meters recently. Anytime I need a "second opinion" I just put batteries into one of my other eight Nikon SLRs and use its light meter. You can try looking at places likehttp://www.adorama.com/catalog.tpl?op=it... andhttp://www.bhphotovideo.com/c/buy/Lightm...
Sounds like an under-voltage problem. Have you verified that your new batteries are fresh, delivering full voltage? The recommended battery is silver oxide, # 76, S76, 357, SR44 and other equivalents. The voltage is 1.55V per cell. Alkaline and lithium substitutes are not as good because the output voltage declines over the life of the battery.
