I put after market rims and tires on and want to disable the tpms i have an 2005 cadillac escalade ext
SOURCE: difference between the cadillac escalade and the cadillac esv
the esv
is longer 16'', longer wheelbase and 21" in length
SOURCE: 2007 cadillac escalade... Onstar disable
you can remove the fuse however you will get a call asking if everything is okay.
SOURCE: the service ride control button appears on my 2005
You must have a leak in your air ride suspension, Going to need a scanner to diagnose where the problem is.
SOURCE: What does it mean when the Service Ride Control
THERES A PROBLEM WITH THE AIR RIDE, THE AIR BAGS,,,,,,,, CHECK UNDER FOR DEFECTS OR OUT OD ADJUSTMENT, MOST OF THE TIME YOU DONT RELIAZE BUT PEOPLE RUN OVER STUFF ON THE ROAD AND DAMAGE A PART OR THE LEVELING SENSOR
SOURCE: cadillac escalade ext will not start dic message
A battery can read 12 volts yet be weak in cold cranking amps, try a jumpstart and if that works have your battery load tested. Im betting your gonna find the battery fails the load test, meaning it needs to be replaced..
