Also known as the Green Blinking Light of Death.
The repair on this is cheap but very time consuming and wit no gaurentees.
There are 4 Capacitors on the DM board and 4 Capacitors on the Formatter board that are more than likely defective and need to be replaced.
On the DM board the locations are C81A2, C81A3, C81B3 and C81B4. They will probably be swollen.
On the Formatter board the locations are C8F19, C8F21, C8F22 and C8F27. Also will probably be swollen. The values of all 8 capacitors are the same. 1000MF/16V. Replace with value 680MF/16V.
While you have the chassi ripped apart, check the power supply board as well. You should fine some swolle caps on it also. Replace with same value of the one you remove.
Now once all of this is done and you put everything back togeather, you have a 50/50 chance of success. I have found that many surface mount caps can also go bad on the formatter board. If your repair does not work, then replace all of the surface mount caps on the formater board that are 10 and 16 volts.
Good luck to you.
