Computers & Internet Logo
Caitlyn S Posted on Mar 20, 2013
Monitor settings screen keeps popping up
It had 4 buttons on the front of the monitor that had to do with the settings. (Exit, sunshine symbol, circle with line down the middle symbol, and Menu) and i ripped the button's covers off and used tweezers to fiddle the actual buttons around and it's gotten to where now it isn't up constantly but it still pops up randomly every now and again, and sometimes it'll go away instantly but sometimes it'll stay until i fiddle with it again. Sometimes it's annoying, how can i permanently fix this problem?
Rajesh Bhavsar
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 65 Answers
  • Posted on Oct 16, 2013
Rajesh Bhavsar
Contributor
Level 1:
New Friend:
Cheetah:
Answers
65
Questions
0
Helped
15086
Points
86
It happens due to excess moisture in air when the switch gets shorted by itself due to dust accumulation ,If in warranty pls log a call or else get it checked by a monitor repair person all monitors have same switch's
5 Related Answers
antiochpc
Kevin Shafer
  • 1314 Answers
  • Posted on Jun 10, 2007
SOURCE: Menu randomly pops up while pushing no buttons....
It sounds like an issue with the power button board and I would certainly make use of the warranty option.
Anonymous
  • Posted on Feb 28, 2008
SOURCE: menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Anonymous
  • Posted on Jan 07, 2009
SOURCE: config screen keeps popping up
A friend of mine had the exact same same problem. I think I fixed it, because it has been 2 hours, without the menu popping up. You need to open the monitor:
- Place it face-down on a flat surface
- Remove the cover of the hinge by gripping it with both hands and gently squeezing and pulling.
- Undo the 4 screws and remove the stand (base)
- Undo the four screws tha hold the cover down (4 corners)
- Use a flat screwdriver to seperate the 2 halves (I used 2, a small one to lift the back, a bigger one for leverage)
You will see a small PCB, fastened by 3 screws, at the bottom (where your menu+on/off buttons are) with a ribbon connection to the screen. Next:
- Unscrew the PCB, and gently lift it out.
- Clean the microswitches and the ribbon cable connection.
- Reassemble the monitor.
To clean microswitches and the connection, I used Kontakt Video 90 spray. There must be sprays on the market where you are. It's basically an alcohol-based cleaning spray. Good for cleaning video/tape/floppy heads, CD/DVD lenses, memory modules, etc.
Anonymous
  • Posted on Jun 14, 2009
SOURCE: Lock/unlock symbol appears in the middle of the screen
hold the menu button between 10 and 20 seconds until the lock changes to unlock
Anonymous
  • 52 Answers
SOURCE: Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
I have a brighten symbol that keeps popping and I can't get it to go away right in the middle of screen
go to set up menu then select the brightness adjustment and then exit.if can get with adjustment turn off then unplugged don't use for an hour to reset the power supply.
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
I have a small screen which appears in the middle of my main screen which is for adjusting contrast ect. I keeps popping up I can not remove it there are buttons in the front for exit ect which will not...
Sounds like the monitor menu is popping up. If so, it is not your computer but the monitor that is causing the problem. Is the monitor menu button stuck?
2helpful
2answers
My HP 2009m goes into sleep mode & shuts down
hmmm is it your monitor going to sleep..or the machine? might the computer still be running?
if it's the computer go to power setting and change to your pref
2helpful
2answers
Stupid padlock/main menu keeps opening and closing DELLe152fp
That is the OSD (On Screen Display) system built-in to your computer monitor. Check that when you hit the ON/OFF button on your monitor, that you do *NOT* hit the 'OSD ON/OFF' button.
Most of the time, the OSD will disappear after 10 seconds of "non-use".
2answers
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
4helpful
2answers
Config screen keeps popping up
Menu keeps popping up
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
