Unit is making ice making ice and water in door operates but is not very cold. Looked in manual and do not see any adjustment for water temp. Any ideas?
SOURCE: ICE MAKER NOT MAKING ICE, WATER NOT FEEDING INTO ICE MAKER
Hi
If
The ice maker has completely stopped producing ice
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
SOURCE: FRS24ZGE is not making ice
Hi Jeff, Had same problem. Turned out that the fill tube for the ice cube tray had filled with ice. I solved the problem by removing the tube from the back and letting warm water thaw the ice. Reinstalled and it works fine. You may also want to try a blow dryer while still in the freezer, but that may take some time. Good luck, Jim
SOURCE: Frigidaire upright freezer-Model # LFFH2067DW. twice
http://www.searspartsdirect.com/partsdirect/part-number/Frigidaire-Parts/Freezer-Parts/297216600/0046/253/Model-LFFH2067DW7/1428/0142000?keySuffixId=NA&productTypeId=0142000&searchModelNumber=LFFH2067DW7&subCompDesc=System&brandDesc=FRIGIDAIRE&modelDesc=FREEZER&blt=11
Thermostat is what I would suspect first.
The defrost timer is the next suspect : http://www.searspartsdirect.com/partsdirect/part-number/Frigidaire-Parts/Freezer-Parts/297216600/0046/253/Model-LFFH2067DW7/1428/0142000?keySuffixId=NA&productTypeId=0142000&searchModelNumber=LFFH2067DW7&subCompDesc=System&brandDesc=FRIGIDAIRE&modelDesc=FREEZER&blt=11
I think the defrost heater is probably okay and it is just getting the wrong signals from the above components. But it is item 14 on this diagram: http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Freezer-Parts/Model-LFFH2067DW7/1428/0142000/R0805140/00003
Hello friend, thank you for your post!
I understand that your Frigidaire refrigerator is not producing enough ice. I would advise to check and make sure that your water filter has a secure connection, if need be uninstall and reinstall the water filter to assure connection. Your filter should be changed every six months, if it is has not been changed recently I would recommend exchanging it.
If you continue to receive low ice production it could be an issue with your water line or water valve, I would seek assistance from a professional for proper diagnose and repair of your appliance. I hope this helps. -Matt
