These two images appear seperate from each other. One is aprox 10in from the right side and the other almost center. Both apear to look like a water mark of sorts, not much more than 2in wide and vertical through the screen. The intensity of these images varies with the back ground screen picture colors. Dark background; highly visible, light background barley seen.
I have the same issue. A have a band down on the far right and a second about 4 inches to its left. I don't ever really remember noticing it until recently. Appears like dust or dirt on the inside of the screen. Is there a cleaning method?
CHECK IT IN THE DIFFERENT ASPECT MODES. IF THE IMAGE STAYS IN THE SAME PLACE REGARDLESS OF ASPECT. THEN YOU HAVE A LCD PANEL PROBLEM. PANEL WILL HAVE TO BE REPLACED.
Click on the Start menu button. Then click on Settings and then on Control Panel.
Double-click on the Display icon or text link. This will open a window named Display Properties.
Click on Background if that tab is not selected. Click on one of the items that appear in the box labeled Wallpaper.
Inspect the preview that appears above the Wallpaper menubox. Use the Display menu to the right to experiment with tiling, stretching or centering the picture that you are previewing. 5
Click on Browse to use an image stored elsewhere on your hard drive. Locate the image and click Open. 6
Click OK to change your background, or wallpaper. Click Cancel if you decide to maintain your current settings.
<li>
<p>Click on the Start menu button. Then click on Settings and then on Control Panel.<br /></li>
<li>
<p>Double-click on the Display icon or text link. This will open a window named Display Properties.<br /></li>
<li>
<p>Click on Background if that tab is not selected. Click on one of the items that appear in the box labeled Wallpaper.<br /></li>
<li>
<p>Inspect the preview that appears above the Wallpaper menubox. Use the Display menu to the right to experiment with tiling, stretching or centering the picture that you are previewing.<br /></li>
<li>
5
<p>Click on Browse to use an image stored elsewhere on your <a href="http://www.ehow.com/how_5177_change-background-picture.html#">hard drive</a>. Locate the image and click Open.<br /></li>
<li>
6
<p>Click OK to change your background, or wallpaper. Click Cancel if you decide to maintain your current settings.<br /></li><br />
<span>Tips & Warnings</span>
<ul>
<li>
For background pictures, you can use scanned or digital photographs, an image downloaded from <a href="http://www.ehow.com/internet/">the Internet</a>, or perhaps some original artwork that you created in a graphics program. Graphics files suitable for use typically end with extensions of .bmp, .gif, .jpg, or .tif.</li>
<li>
Wallpaper consisting of large image files will consume memory and system resources. Consider using a small image and tiling it if resources are scarce.</li></ul><br />
you will need to replace 2 stk ic [ parts ] after that the technician will have to realign the picture, sometime also some resistors get bad along with one or 2 fuses
50V500 ONLY GHOST: May be described as "Out of Convergence" but ghost is still attached to main image. CONDITION: A "ghost image" appearing to the left or right of images in the picture.Can be varying shades of a primary color (red, green, or blue) as well as gray.Can easily be seen in the 4 x 3 mode, at the edges of the picture. CORRECTION:
To correct the problem, please do as follows:
Access I2C Menu. (See page 57 of the Service Manual).
To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
Figure 1
BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
Be sure to press SELECT after each change to SAVE the new Data.
Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
Figure 2
Move the joy stick to the right to cursor right once.The next page will appear with the word GHOST highlighted.
Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3.You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
Press the "EXIT" button three times to return to normal picture.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Replace the convergence ICs. They are located on a large aluminum heat sink withSTK numbers stamped on them. They cost about 10.00 each. They have to be soldered in. Let me know if you need anything further.
