Question about Kenmore Oasis HE 27062 Top Load Washer
I want to bypass the lid lock on a Oasis 27062600.
Wires at stitch are Red,blue,white black green and brown.Thanks
  • 113 Answers
Not on an oasis..cant bypass.
Posted on Mar 03, 2009
6ya staff
SOURCE:
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1995 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1995
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Distributor
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector)
Parking Lights: Red/Black - (+) Above Fuse Panel
Head Lamp: Red/White - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Blue/Yellow
Windows DOWM: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
VSS Wire : Yellow/Blue - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 03, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1994 Honda Civic This...
1994
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Hood Pin: n/a
NOTES: - none -
CRUISE CONTROL:
NOTES: 4000PPM
on Apr 01, 2010 | Honda Civic Cars & Trucks
1991 honda accord radio wires cut need schematic
Radio Constant 12V+: Blue/White
Radio Switched 12V+: Yellow/Red
Radio Ground: Black
Radio Illumination: Red/Black
Radio Dimmer: n/a
Radio Antenna: Driver’s Pillar
Front Speakers Size and Locations: 5 1/4′ Doors
Left Front (+): Blue/Green
Left Front (-): Gray/Black
Right Front (+): Red/Green
Right Front (-): Brown/Black
Rear Speakers Size and Locations: 6 1/2′ Side Panels
Left Rear (+): Blue/Yellow
Left Rear (-): Gray/White
Right Rear (+): Red/Yellow
Right Rear (-): Brown/White
May 12, 2009 | 1991 Honda Accord
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1993 Honda Civic This...
1993
Constant 12V+: White/Blue
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Parking Lights: Red/Black - (+) Above Fus Panel (White Connector)
Hood Pin: n/a
Factory Disarm: Disarms with Unlock
Door Trigger: Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) Driver's Door at Door Lock Module
Horn: Blue/Red - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Orange/White
NOTES: - none -
CRUISE CONTROL:
NOTES: 4000PPM
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1992 Honda Civic This...
1992
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Hood Pin: n/a
Windows DOWN: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
RADIO INSTALLING
there is a code for color!? ok, wait im searching...
found it! here you go, hope it helps...
Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
Jun 19, 2008 | 2001 Chevrolet Tahoe
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1988 - 1991 Honda Civic...
1988
1989
1990
1991
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Accessory: Blue/White - Ignition Switch Harness
Trunk Pin: Green/Black - (-) Harness from Dash Indicator
Parking Lights: Red/Black - (+) Fuse Panel
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Red - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, 13-pin connector.
NOTES: 4000PPM
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
659 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
