Question about Mach Speed Trio Stealth Pro 7 7" 4 GB Slate Tablet - Wi-Fi - ARM Corte
Fix trio tablet screen
Went on a plane a couple times now it has a crack in the screen and i cant use the upper part of my tablet
    New Friend:
Smear butter on it, then apply water. After that, use 1 tbsp of corn syrup and glue mixed. Wait for it to dry for at least 24 1/2 hours
Posted on Jul 26, 2013
6ya staff
SOURCE:
Sat on trio tablet on accident it cracked now i cant touch
take it in to a phone repair shop and have a new screen fitted
Nov 13, 2016 | Tablets & eReaders
My screen is cracked how do I fix it
you cant but some cell repair shop can weird i just put my phone in for the same thing mine was cracked for the longest time but i still used it then the phone screen one day went black so i asked a friend he told me were and for only 20 bucks SWEET so they look at it and tell me it would be $120 bucks i asked why for my friend
told me 20 he told me that i had broke both the upper and lower glass he told me that upper glass only is 20 but both are 120 thats for a GS3. so on a fire is more money for bigger screen so if u still see something careful and to much heat would crack it.do some research look around compare prices look for the good price with great workmanship hope this
Aug 13, 2015 | Amazon Kindle Fire HD
When i turn it on it says trio stealth g2 and stays there and won't turn the rest of the way on.
Perhaps the HARD RESET PROCESS can help you, Merrill. I've posted my suggestion as to how it's done HERE. ( http://www.fixya.com/support/t25341481-trio_stealth_new_when_power_goes ) , so you may findt that information useful.
I've had good success with HARD RESETTING when trying to correct errors like forgotten password, or forgotten lock-patterns. However, I've had a Trio Stealth G2 that displayed the SAME problem as yours, Merrill, and it would NOT respond to ANY attempts at resetting. I tried every combination I could : pressing volume down (-) and power; volume UP (+) and power; volume UP & DOWN (+ AND -) and power. It refused to boot. But since the case and the screens were in great shape, I went on Ebay and bought a Trio with a cracked screen, swapped the motherboard from THAT tablet and it worked perfectly.
Final caution, though: ask the Ebay seller to guareantee the physical condition of the ports and other controls on the unit before you buy it. Remember you need a working motherboard.
Best of luck to you, Merrill!
Mar 13, 2015 | Trio Stealth G2 7 inch Tablet with 8GB...
My tablet screen is cracked i have a trio: stealth g4
take it to a phone /tablet repair shop and get a new screen/glass
Jan 18, 2015 | Tablets & eReaders
Its a crack inside my screen and i didnt know how to fix it so i opened my tablet to see what was wrong and i didnt see anythning. so i put it back together and its not turning on!!!!!!! please hel
(1) Is the battery charged? I'd connect the charger for at least 10 to 15 seconds anyway, while doing the following step.
(2)Are you holding the Power button long enough when you try to restart the tablet? It will need to be held down for a few seconds (perhaps 5 or 6) while you wait for the TRIO start-up screen to appear. Once it gets there leave the tablet to boot up fully.
If that does happen without further glitches should be able to go back to using the tablet as before.
(Was it working even with a cracked screen? Were you able to get the cracked touch-screen - I'm assuming that was what is cracked- to accept your fingertouch-inputs? Can you select items from all areas of the screen? If it was doing THAT, and it does it again NOW, I'd forget about the cracked screen , put a screen-protector on my tablet and press on ahead! Lucky dog!)
Nov 30, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
My trio 4.3 android tablet has a cracked screen and won't unlock
The resistive touch layer is right under the glass. If it is damaged by the crack it won't respond as normal.
There is little you can do about this, other than replacing the screen.
May 18, 2014 | Mach Speed Trio 4.3" MID Tablet - 87837
I accidentaly stepped on my tablet and the sscreen seems to be cracked. Where can i buy a screen replacement, and how do I replace the screen without damaging tablet more?
Ebay has the screen but you need to be sure of what model you have,it is difficult if you are not into electronics to replace it and you need to buy the tools,google how to fix it on the internet,So if worried that you cant fix it take it to an Apple store.
Dec 28, 2013 | Mach Speed Trio 4.3" Tablet with 4GB...
Screen is white when on
Time for a new screen... the crack mostly got worse and has damaged the liquid crystal glass.
Dec 17, 2013 | Mach Speed Trio Droid 2GB Internet Tablet...
My tablet cracked inside the screen and now i cant do anything with it
it depends if the tablet is worth the time 1-you can file claim were you had your flight.2-find out the model number of your tablet then go to e-bay type in the model number asking for a LCD screen you can buy it new or used if you like the price you buy it,if your careful and have the time you can replace the screen your self you'll need a set of mini screw driver set.3-if you don't want to bother then you can go to e-bay set an account and sale your tablet as it is. good luck. d,r,claudio
Jan 08, 2018 | Tablets & eReaders
Mach Speed Trio Stealth Pro 7 7" 4 GB Slate Tablet - Wi-Fi - ARM Corte Logo
601 people viewed this question
Top Mach Speed Trio Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Mach Speed Trio Computer and Internet Expert? Answer questions, earn points and help others
