This washing machine is 3 years old and was working fine. This happened once before, under warranty. The service agent powered on while holding down other buttons to reset the electronics and all worked OK.
Does anyone know the ''maintenance reset'' startup buttons?
Hold reset and start buttons down, while turning on. Hold down for about 10 seconds.
If you're getting an E90 error code, which means communications error, it means you have a dodgy connection between the main board and the control panel.
Disconnect the power completely, open up the top of the machine and reseat the plugs on both ends on the blue ribbon cable connecting the front panel display to the main board. (The main board is the big white plastic thing with all the wires running into it).
Do the reset steps when turning on again, should be good to go, otherwise it's a bit more serious and you'll need the tech back.
I had a similar problem with my washing machine too, I was unsure of what the problem was and I was directed to the below website, in the end i paid for a fixed price repair and it was fixed pretty quickly, you may find this helpful too.
same problem
same!
