Try to turn it off and on. In the summer no was texting me until my phone died. Then I turned it back on and receive messages. If not that try to update your roaming capabilities or contact your provider.
First Option: Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So Secend Option: Your Phone Network IC Fault So Please change Network IC And Network Signal Problem will Solved if it is there isn't much you can do on this side of the network. Contact your phone company.
It is frustrating when only your phone cannot send text messages no matter how strong the network signal is. Sometimes you feel nobody cares about or remembers you because nobody calls or texts you but actually there are. Your phone just can't be reached or can't receive text messages. When these happen, turn off the phone; remove the battery and then the SIM card. Insert the SIM card to another phone and try sending text messages; if you still cannot send text messages, remove the SIM card and let it sit off the phone for at least fifteen minutes then insert it gain. You should be able to send text messages after that, but make sure you have credits.
The next thing you should look into is the phone. Make sure network signal is present then insert a known good SIM card in your phone and try sending text messages. Reset the phone if you still cannot send text messages, but back up important files and data, such as contacts, videos, images, and messages, before doing so.
One simple way to "reset" the phone is by removing the battery and letting it sit for at least fifteen minutes. Another way is by restoring the phone settings to factory settings. Simply navigate to settings then phone settings and select "restore to full factory settings" depending on the brand and model of the phone.
This tip is not intended to solve virus or firmware problems but rather to avoid unnecessary visit to the service center and save few bucks from a problem only caused by a simple electronic glitch. Check the network signal strength and your credits before jumping into any conclusion.
Hi, issues like this are related to your Sim card (network), not your Cell Phone . In most cases, regarding the text messages, the problem is from the Service Operator. Have you tried the Sim card on another phone? If not, remove the Sim card, insert it on another phone and try sending a message from another mobile to you number, or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset, then you will need to call the customer care of your Network Operator and tell them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think it's very much important in your case, well, if you wanna try, just check the text message settings and verify that the message center number (which is currently in use) is the same number which is on another phone with the same network (the other Sim should be of the same network in your area). If it's different, make the changes and save the settings. Also disable the "Receive Via" or similar settings.. (I can't recollect the exact settings as i don't have the same model with me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset, don't bother to change the settings or to make any changes with it, first call the customer care and verify from them, you may make mistakes instead of fixing it.
We are still not sure that it is your handset, If you are using two different phones with two different network mode, that could be the problem. If your phone (able to send messages) is using 2G (GSM) signal, that's fine. And your other phone is using 3G-3.5G (UMTS) signal and you are not able to make a call or even send text messages, then, that could be it, you have to switch its network mode to 2G (or GSM mode) because with 3G, the more mobile uses the signal, the lesser the coverage.
Sounds like the phone hasn't been unlocked properly. I had a similar problem and eventually just changed my sim to the original phones network. This solved all problems but i don't know wether this is the full solution to your issue. I tried to help best as though dude.
Cheers.
