Question about Kenmore Washing Machines
Washer wont drain and go to spin - Kenmore Washing Machines
  • 113 Answers
Most likely needs a new lid switch. You can get it at www.shop.washermd.com. DAVE
Posted on Mar 03, 2009
6ya staff
SOURCE:
Kenmore FL washer #592 49042 Won't drain or spin.
If the washer won't drain water the drain pump might be defective. ... If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself.
Jul 04, 2018 | Washing Machines
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Wont spin or drain
Does the machine agitate if so this eliminates the motor coupling could be a bad timer place unit in spin if motor hums then power going to motor eliminates this check the drain pump it is white and attaches to the motor with 2 spring clips if there is something stuck in it or a bad bearing won't drain if a washer cannot drain it will not spin hope this helps.
Jan 19, 2014 | Amana NTW5400TQ Top Load Washer
My washer wont drain the water....It spins but wont drain
This must be a brand new Kenmore 20.6 cu. ft top freezer refrigerator. I have serviced over 10,000 refrigerators and freezers. Never once did i see one that had a washer, let alone one that spins but wont drain. Maybe you should try the washer forum.
Mar 15, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
I have a Kenmore washer tube wont move to spin out
Hi, Do you know if the washer agitated at all? If the washer does not agitate or spin, the coupler is most likely the cause. If the washer agitates and does not spin, it could be spin basket drive or transmission.
Please let me know so I can assist you further.
Vic
Jun 27, 2009 | Washing Machines
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
May tag washer spin cycle wont spin
check the pump ,,, if pump wont pump out the washer wont spin till it gets down so low / larryyb
Dec 05, 2008 | Maytag PAV2300 Top Load Washer
Whirlpool Washer wont spin or drain
check your run capicitor
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 01, 2008 | Washing Machines
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Oct 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
130 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
