Door was ajar, red light beeping. Closed it, beep went off but red light stayed on by high temp. Some things thawing out
SOURCE: door is closed but door
Usually on most vehicles you will find the switch in the catch on the door, not knowing what vehicle you have I can't be any more specific then that.
Some vehicles us the interior light door pin also, but it really is dependent on vehicle make, model and year.
SOURCE: I have an upright Kenmore
it means it is aprox 8 degrees below cut out temp keep it running it will catch up
SOURCE: door was not sealed tightly
The door seal has a magnetic property to it. Until the freezer gets to a certain degree the magnetic porperties of the door seal dont react properly. Make sure the door seal is properly adjusted. If the door was left open it could have semi warped the door. This gets corrected when temp drops to correct temp. Reset freezer by unplugging and waiting for a few minutes. If problem persist contact appliance technician.
If you have any more questions you can comment me back.
Thank you for your post, friend!
Based off what you are describing it sounds like a possible issue within your control panel or door switch of your Frigidaire freezer, LFFH21F7HW6. You have completed a reset on your appliance by disconnecting power. I would recommend seeking assistance from a professional to properly diagnose and repair your freezer. Hope this is helpful. -Matt
Hey friend, thank you for your post!
In order to stop the door ajar alarm from beeping when the door is closed you would need to reset the alarm. If you have done that and it continues to beep it could be an issue within the switch or panel of your Frigidaire freezer. I would recommend having a professional come out to properly diagnose your appliance. -Matt
