I'm printing stake labels for a greenhouse and the printer is only printing the top half of the label. It seems to be starting to print at the correct spot consistently, but it's only printing the first line of text on each label. I have printed another type of label (loop label) on this printer successfully. I'm using NiceLabel Pro to print the labels.
SOURCE: tec 472 qq no print
First of all can you print just from the printer ie
Turn on the power while
holding down the [FEED]
key and [PAUSE] key?
SOURCE: I am using a Zebra
Label position may be off. Power on while pressing the cancel key for 10 seconds. This should print a configuration label. Use large label for this. Check the parameters, specifically top position and tear off position. The default is 0. You might also check the main drive belt for stretch or missing teeth. You need a user manual for that printer because there is no lcd panel. It is not user friendly without manual.
SOURCE: My TEC B-472 printer is
Check if you are not sending T00C20 commands or check the size of the label
