Two step process, first step we will Deregister your Amazon account and then we will reset the device. Step 1: Status Bar More + select Account - Deregister Step 2: Status Bar More + Select Device - Reset to Factory Defaults
If your Kindle is running slow, here are a few things you can try to fix it:
Restart your Kindle: This is one of the easiest and most effective ways to fix any performance issues. Simply press and hold the power button for 20 seconds until the device turns off, then turn it back on.
Remove any unnecessary content: If you have too much content on your Kindle, it can slow down the device. Remove any books or files that you don't need.
Clear cache and data: Clearing the cache and data can help to speed up your Kindle. To do this, go to "Settings" > "Storage" > "Cached Data" and tap on "Clear Cached Data."
Update the software: Make sure that your Kindle is running the latest software version. To check for updates, go to "Settings" > "Device Options" > "System Updates."
Disable Wi-Fi and Bluetooth: If you're not using Wi-Fi or Bluetooth, turning them off can help to improve performance.
Reset your Kindle to factory settings: If none of the above solutions work, you can try resetting your Kindle to factory settings. To do this, go to "Settings" > "Device Options" > "Reset to Factory Defaults."
Keep in mind that some older Kindle models may experience performance issues due to hardware limitations. In that case, upgrading to a newer model might be the best solution.
Starting with the Kindle Fire off, press and hold "Volume Down" and "Power" simultaneously. The Amazon system recovery screen should appear. Use the volume buttons to toggle the selection to "wipe data/factory reset". Press the "Power" button to choose the selection.
Try using a different charger and cable to make sure the battery is being properly charged. Your penultimate option is to back up all your files and perform a factory reset. Go to Settings > Device > Reset to Factory Defaults > Reset. If nothing has worked, then it's time to contact Amazon.13 Jun 2016
To reset your Kindle, press or tap the "Menu" button on the Home screen and select "Settings." The "Settings" screen appears. Press or tap the "Menu" again and select "Reset to Factory Defaults." YourKindle will start the resetting process and power off automatically.
Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
Choose "Menu" again from within the Settings menu. This displays a different menu than before.
Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
Wait while your Kindle restarts.
E-Reader Factory Reset
Press your Kindle's Menu button. Select "Settings" from the menu.
Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
Hold the Power button down for three to five seconds. A Shutdown window appears.
Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
Press the Power button to turn the device on again.
Fire Hard Reset
Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
Tap the "Settings" option and select "Device."
Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Bring down the top menu and touch the "more" selection. Touch Device. At the bottom of this list you will see "Reset to Factory Defaults"-touch that option. You will get a warning box. Touch Yes. This will remove all personal data from the device.
To reset a Kindle Fire to factory default, tap "Settings" (the gear-shaped icon near the upper-right corner of the screen, then tap "More". Scroll down and tap "Device", then scroll down and tap "Reset to FActory Defaults".
To perform a hard reset of the Kindle just press and hold the power on button for 20 seconds as described in the Kindle Support web site for dealing with Frozen devices.
If you want to reset your Kindle back to Factory defaults then you would need to press the Menu button, then go into Settings and you will find an option there to Reset to Factory Defaults.
