Question about Splendide 2000S Vented Washer/Dryer
My splendide washer/dryer combo is leaking water from under the right rear corner of the unit. The drain hose is located there but the water is coming from further under the unit. Could it b e the water pump?
    Top Expert:
  • Splendide Master
  • 10,764 Answers
Yes
Posted on Oct 29, 2017
  • 1 more comment
  • David Spradling
    David Spradling Nov 25, 2017
    possibly cracked from freeze damage or pump seals
  • Sandy White
    Sandy White Apr 29, 2018
    Leaking must be a common problem last year was my first year no problems now it leaks all the time I use it
  • Sandy White
    How does it get fixed how can pump seals be found does anyone know the answer
Anonymous
SOURCE:
prem mathew
  • 1294 Answers
SOURCE: Splendide 2000S
Go to: repairclinic.com
Posted on Mar 13, 2008
Anonymous
SOURCE: Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Posted on Nov 01, 2008
Anonymous
  • 3 Answers
SOURCE: Broken door handle on Splendid 2100 RV Washer/Dryer Combo
The Splendide distributor in OR sells handles for about $45.
Posted on Jan 28, 2009
Anonymous
  • 68 Answers
SOURCE: Splendide 2000 S runs through cycle but water left in unit (hums)
The drain pump is probably clogged. or drain hose is kinked. I have a trouble shooting guide if you are interested.
Coach Tech RV
734 777 6432
Posted on Mar 23, 2009
dennis dodge
  • 1891 Answers
SOURCE: My 2000S combo will not dry
make sure hot is on hot and cold is on cold . and ck the out side vent hood to see that it's clear and will open .. mm
Posted on Dec 12, 2009
Splendide 2000s
My Splendide' was worn out after 6 years. Perhaps yours is as well?
I replaced it with a LG ventless washer/ dryer combo. If you have room I strongly recommend it.
It's a much better machine with 25 year warranty :)
Aug 21, 2014 | Washing Machines
Supra washer/dryer combo leaking significantly
In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Mar 20, 2013 | Supra SW5L65D Front Load Washer / Dryer
Water outlet hose replacement
Hi, you could try copper pipe, 22mm, or 3/4" (ish) ( plumbers) and jubilee (adjustable clips, from hardware store) to clamp the two together.
Dec 06, 2017 | Splendide Comb-O-matic 6200 Non-Vented...
Splendide Model WD 802 . Would not drain water.
I have a Splendid Washer/Dryer combo Model # WD802.
The water is not draining. I have taken the filter out, cleaned it, still does not drain. Gets to the drain cycle and does not go any further. Same in every cycle.
Anyone with suggestions for repair ? Thanks
Aug 01, 2011 | Washing Machines
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Coach Tech RV
734 777 6432
Mar 23, 2009 | Splendide 2000S Vented Washer/Dryer
LG washer/dryer combo will not drain water
easy first unplug unit..take back remove phillips head screws...now the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
Aug 18, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Splendide 2000 doesnt work at all on wash
I have exactly the same issue. The door normally locks, but doesn't do anything on wash.
Jul 29, 2008 | Splendide 2000S Vented Washer/Dryer
Washer leak in an estate washer
i have Had 3 estate washers leak on all four corners....there junk went with ge instead......estate washers are horrible
Mar 20, 2008 | Estate TAWX700JQ Top Load Washer
Splendide 2000S Vented Washer/Dryer Logo
1,436 people viewed this question
Top Splendide Washing Machines Experts
Marvin
Marvin
Ekse
peter gittos
peter gittos
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
