Ricoh Aficio GX E3300N InkJet Printer Logo
Anonymous Posted on Mar 23, 2013
Printer turned off and will not turn back on,
Put new ink in, it did maintenance, started to print then just turned off and will not come back on.
Anonymous
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 20 Answers
  • Posted on Mar 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Cheetah:
Answers
20
Questions
0
Helped
2200
Points
42
Try unplugging it and plugging it back in, then see what happens.
1 Related Answer
Anonymous
  • 2961 Answers
  • Posted on Dec 20, 2006
SOURCE: Brand new Printer lights flashing
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
2answers
The cartridges are new HP cartridges. I unplugged the printer and plugged it back in. I cleaned the copper dots on the ink and on the printer. I took the ink out and put it back in correctly several times....
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Hi, My Canon MP210 printer is displaying E3 code. The colour light and alarm lights are illuminated constantly and black one is flashing. When opening the "lid", the cartridges do not align to...
I have workaround for the empty tank issue:
- buy or borrow another not empty tank
- place it in
- start the printer
- it recognises the "new" tank
- turn off the printer
- put back the old, empty, but refilled tank
- turn on the printer
- print something
- it will pop up a dialogue window saying
"The ink level of the black/color tank cannot be
determined. The ink level determining function will be
disabled for the black/color tank.
If you want to continue printing without this function
press the Start button on the printer."
- Press the Start button on the printer and ignore the
button 'Cancel Printing' appearing on the dialogue window.
- The dialog window disappears.
You can print your refilled tank as many times you want from this time.
When you go to 'Printers /Canon /Properties /Maintenance / Printer Status / Ink Information' it says that the ink level measuring function has been disabled for: black [40] / color[41]. You can ignore this this message, the printer will work perfectly without this stupid function.
Cannot print
Change the cartridge ...
but, in case E3
- place it in
- start the printer
- print something
2helpful
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
2helpful
2answers
Black will not print
Try this one, Turn on the printer, Take out the inks, remove the printhead, put back the printhead make sure it will snap and you hear a click, put the inks back, wait for the printer to initialize, Press the Menu button, look for Calibrate printer, then print calibration page,. Load a regular paper. Then try to print a demo page If same problem persist call this no for further assistance 1800 421 6699
Thanks
Put ink cartridge in printer and now it won't print
You might have to do a MAINTENANCE on it. Start, Settings, Ptinters and Faxes, Rt click your printer, Properties and somewhere in there is Print Test Page or Clean Print Heads. Does this do anything?
You can also hold down one of the buttons on the printer while turning it on and force it to do non-stop test prints. Turn off to stop
2helpful
WONT PRINT CALIBRATION PAGE
Take out the cartridges and turn off the printer. Turn it back on, and THEN put the ink cartridges in. After that, try to print the calibration page.
If this does not work, clean your printer using the cleaning maintenance from your HP printer software
3helpful
Hp 3310 photosmart only prints in yellow
On the left side of the print head carriage is a white plastic gear that drives the ink pump. Check it first to see if its firmly in place, has chipped or worn off teeth or looks damaged in some other way.
If this white gear driving the ink pump is damaged or looks odd let me know right away so we can address this issue.
Now, there is a trick for resetting your particular HP printer. This sounds and is convoluted but it will work. However, the system will think all your ink cartridges are full. If they are rather full okay. If they are near empty you will want to run this hack again as the ink nears low. You won't get a ink low warning correctly after this until you've installed new full tanks eventually.
Turn the printer on. At the same time, using your left hand, press the OK, Cancel, Black, and Color buttons down and hold them down. While holding these down buttons use your other hand to turn the printer off, still holding the four buttons down with the left hand. Once the printer has powered down fully you can release the buttons. Now, the printer will initialize and then run a maintenance check. If you printer is otherwise okay, no damaged circuitry or gearing you will be fine. Turn the printer on. It will start up and shut itself off, this is expected. Once it is off again, turn it back on once more and this time the printer will run the maintenance routine. Have paper in the feed tray.
1.) Check left side of printer carriage for the white gear that drives the ink pump. Look to see if the gear is off, broken has worn or chipped teeth.
2.) Turn the Printer On.
3.) Hold down the OK, Cancel, Black, and Color buttons with your left hand and hold them down.
4.) Use your other hand to turn the printer off. Keep your left hand on the buttons until the printer is off.
5.) Turn the printer on, wait for it to turn itself off. Have paper in the feed tray.
6.) Turn it on again and it will enter the maintenance mode. Follow any prompts during the maintenance mode, if any.
You should be back in business now. If not, try the routine again, sometimes you have to run it more than once. Should it still fail, let me know as you may get an error message and error number.
Use the Comment Text Entry Box below to comment back with any other questions or point out failures in this hack.
Regards,
Worldvet
1helpful
White horizontal streaks in documents
I Am Experiencing Poor Print Quality With My Dell™ Printer
Table of Contents
Verify the Printer Ink Levels Using the Dell Printer Solution Center
Clean the printer contacts and print a test page
Clean the Printer Nozzles Using the Dell Printer Solution Center
Dell™ Printer Additional Information
» Verify the Printer Ink Levels Using the Dell Printer Solution Center
Poor print quality of a document or picture may be the result of low ink levels or dirty printer nozzles or contacts.
To check the printer's ink levels, perform the following steps:
1.
Click the Start button, point to All Programs, point to Dell Printers, and then point to Dell (printer model).
2.
Click Dell Printer Solution Center.
3.
Locate the printer's ink levels on the lower right corner of the Dell Printer Solution Center window.
4.
If the printer's ink levels indicate that ink cartridges are empty, click the Order Ink button to place an online order for replacement ink cartridges.
For information about ordering ink for your Dell printer, refer to article: Obtaining Ink for a Dell™ Printer
Back to Top
» Clean the printer contacts and print a test page
To manually clean the printer nozzles and contacts, perform the following steps:
1.
Turn the printer off and remove the power cord from the back of the printer.
2.
Open the printer lid.
3.
Manually move the ink-cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right hand side of the printer.
4.
Take a warm, semi-damp paper towel and gently clean the wiper on the right side of the maintenance station.
5.
Lift up on the cap(s) that cover the ink cartridge(s).
6.
Remove the ink cartridge(s), and using a new warm, semi-damp paper towel, gently clean the contacts on the ink cartridge(s).
Verify that the contacts on the ink cartridge(s) is/are sufficiently dry prior to re-inserting into the printer.
7.
Re-insert the ink cartridge(s) back into the correct printer slot(s).
7.
Close the printer lid.
8.
Re-attach the printer power cord to the back of the printer unit.
9.
Press the Power button to turn the unit back on.
10.
11.
12.
13.
Click the Print a test page icon.
A test page prints.
Back to Top
» Clean the Printer Nozzles Using the Dell Printer Solution Center
To clean the printer nozzles and contacts using the Dell Printer Solution Center:
1.
2.
3.
4.
Click the Clean to fix horizontal streaks icon.
5.
Click the Print button.
Note:
The printer will make sounds when cleaning the nozzles that are not commonly heard during normal usage
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
