I am using a Telus remote control. The TV is a LVQ 32HLA
SOURCE: universalremotecodes
turn on tv set.... press the button set in remote control until light lit on then press power button again and again untill ur tv set off then press set..
SOURCE: NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
SOURCE: universal remote control tvrc1n
The instruction manual can be found here:
www.ganache.be/pdf/TVRC1N_manual.pdf
Hope it works for you
SOURCE: I have a RCA Remote universal control. I need the
Polaroids are not very friendly with universal remotes and many have to be custom programmed.
You can try the following codes 1004,0765,0865,1523,0150,1276,0178 and 0775.
If these do not work try a code search with the remote, or perhaps try the mitubishi codes.
SOURCE: have a universal large button remote controller
TV
Sanyo
0154, 0159
These codes came from the listing on "hifi-remote.com" If your remote only requires three digits, drop the zero. Hope this helps.
